Old 10-13-2009, 09:00 PM
SoDakMac's Avatar
SoDakMac SoDakMac is offline
Vehicle: 2014 Ram 1500 Limited
Trim Level: Longhorn Limited
Color: Deep Cherry Red Crystal
SoDakMac is on a distinguished road
Default Auto Climate control Question
Question about my 09 Laramie’s climate control system. In all the vehicles with auto climate controls I have owned the past 10 years or so the heater blower does not activate until the engine temperature reaches a certain point to avoid blowing cold air in your face. However, my Dodge’s system when on auto starts the blower immediately and blows cold air around for a few miles (we have unseasonably cold weather currently). I have a 2006 300C which does not do this. I was going to ask my service manager about the situation and see if it is a software problem. I cannot believe they designed the system like that on purpose. Anyone else notice this problem?
Old 10-13-2009, 09:06 PM
Good question . I have a '06 300 SRT8 car . Will have to check what mine does in the a.m.
Old 10-14-2009, 02:30 PM
iRockCrawler's Avatar
iRockCrawler iRockCrawler is offline
Vehicle: 2009 Dodge Ram 1500
Color: Mineral Gray Metallic
Rep:44
iRockCrawler is on a distinguished road
and the A/C turns on by default when you go to auto.. even when it's -3 like this morning... wtf
Old 10-14-2009, 02:38 PM
glamontagne's Avatar
glamontagne glamontagne is offline
Vehicle: 2009 Dodge Ram Crew
Rep:55
glamontagne will become famous soon enough
I have the same thing happen to my A\C in the morning. I thought I was doing something wrong.
Gary--2009 Black Ram Crew 5.7 Truck Champ Stainless tube steps,Tekstyle Tonneau Cover, LED Interior, LED License Plate Lights, LED Reverse Lights, LED Cargos, 5900k Headlights and Fogs.
Old 10-14-2009, 05:22 PM
Dodgie Dodgie is offline
Rep:29
Dodgie is on a distinguished road
Doesn' t it have a sensor to get rid of the humidity !!!?? And does this automatic trough the a/c ? Manual perhaps ??
Old 10-14-2009, 06:47 PM
LadyRam's Avatar
LadyRam LadyRam is offline
Vehicle: 2009 Dodge Ram 5.7L Hemi Crew
Color: Stone White
Rep:56
LadyRam will become famous soon enough
same here
my ford and pontiac had the auto temps and they didn't start blowing until the engine temp warmed up some
'09 Dodge Ram CC Laramie 5.7L, Stone White; fully loaded
Mods: Chrome Gas Door, Chrome Bedrails, Chrome Bug Shield, Chrome Oval Steps, Access Cover, Rhino Liner, Tinting, Stainless Door Sill Guards, Flowmaster 50 H.D., Recon LED Lightbar, K&N Filter, Power Tailgate Lock, EZ Down
Old 10-14-2009, 07:00 PM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
In my '07 the blower kicks on whenever the auto start is used, but i have manual control over it so just set it high.
If your temp controls are all digital i'd have the dealership look at it as it may need a flash for this. Seems strange that the a/c would kick on automatically unless it was already set to on when the truck was turned off.
Kurtis
Old 10-14-2009, 09:34 PM
Rep:44
Yes, it does... according to the manual. I read that the day I picked up the truck as the A/C was always on in auto unless I turned it off.
But this is to stop the window from fogging up.. I have never had to use A/C on any other vehicle to prevent windows from fogging or clear it in the morning.. and while there is still humidity at -3, A/C ain't gonna do a thing for it..
Old 10-15-2009, 01:11 AM
Airdog's Avatar
Airdog Airdog is offline
Trim Level: Sport 4x4
Color: Detonator Yellow
Rep:37
Airdog is on a distinguished road
Pop the hood next time you start the car on a cold morning. Almost all vehicles have a sensor that disables the a/c compressor in cold weather (not sure what the low temp cutoff is). Even if you turn the a/c to max and put it to the coldest setting in cold weather you'll find the compressor probably isn't on even though the light on the controls will be.
The compressor will kick in as the outside temperature goes up because the a/c coil will actually help draw water vapor out of the inside of the car (to reduce fogging). Humidity in the atmospere usually increases as temperature increases. As the temperature outside lowers towards freezing, the humidity in the air decreases as well. No humidity... no compressor needed to help draw the moisture out.
The remote start on the Rams is supposed to turn on the defrosters, **rear defrost, **heated mirrors, **heated seats, and **heated steering wheel (**if equipped).
~Airdog .
Old 10-15-2009, 04:39 PM
Rep:44
Originally Posted by SoDakMac View Post
However, my Dodge’s system when on auto starts the blower immediately and blows cold air around for a few miles (we have unseasonably cold weather currently). Anyone else notice this problem?
I tried mine today with everything on auto and the blower was on but at a very low setting (not noticeable but it sounded like it was on) . its was -3C when I got in the truck.. after a little warm up and 2km of driving, the blower started to increase speed. It also said delay on the climate controls then increase speed when the delay went off.
If yours starts fast right away, I would get it checked out.
