Old 10-14-2009, 03:34 PM
RAMjet's Avatar
RAMjet RAMjet is offline
Vehicle: 2007 RAM 2500
Trim Level: SLT Quad Cab 4X4
Rep:14
RAMjet is on a distinguished road
Question A/c problems on 2007 ram 2500 slt
Boy, I wish somebody from the forum could help me out with this issue...
While trying to get rid of an slugging noise comming from the accumulator and noticing that cooling capabilities had decreased significantly, I opted to have the system recharged. This solved the issue for a couple of months...
But again the thunk reappeared and A/C system lost all cooling...
Last week I took my truck to an A/C reapir shop and found a refrigerant leak coming from the evaporator area, so the mechanic told me in order to get the A/C fixed requires the evaporator to be replaced along with the accumulator... come on... mi truck barely has 44K miles... how would and evaporator get damaged so soon? It's there a way that a faulty fitting at the evaporator could be causing this leak?
Please I need ideas...
Cheers!
07 RAM 2500 SLT, CUSTOMIZED BORLA EXHAUST SYS, COMPLETE RANCHO LIFT KIT, 37" BF GOODRICH M/T KM2
Old 10-14-2009, 03:48 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Accumlator, evap core and orifice tube are the cheapest things to change, if it leaking there might as well change it. As for faulty fittings at the evap, I doubt it, I dont really think there are any. Like you said, after a recharge it fixed it temporarily, so you know for sure you have a leak, and if its coming from around the evap, might as well change it, just my .02
Old 10-14-2009, 08:53 PM
I wasn't aware of the newer rams having problems with evaporators like my gen of rams . Might want to check with the dealer and see if there isn't a recall or extended type warranty before you pay for the repairs .
Old 10-15-2009, 09:47 AM
RAMjet's Avatar
Rep:14
Many Thanks for your replys!!
