Old 10-15-2009, 09:14 AM
jbbates jbbates is offline
jbbates is on a distinguished road
Default A/C only works while driving, heat works on one side
I have an '02 Quad Cab Ram and I have recently discovered some strange happenings with my A/C and Heater.
The A/C works and blows pretty cold but ONLY when I am driving. If I am idle and stopped the A/C slowly gets warmer and warmer, then I hear a hissing noise, like the sound of pressure being released, and the air is very humid and warm. Even if I hold down the throttle while at idle, the a/c still doesn't cool down until I start moving again.
Now that the colder months are coming I've had to begin using my heater and I have noticed that the two driver's side vents do not blow hot air at all. However, the passenger side vents blow fairly warm air but not like they used to.
At first I was thinking that I might have a coolant leak but now that my heat isn't working correctly, I'm thinking the problem may be a bit more complex.
Any help or advice is greatly appreciated.
Thanks in advance.
J.B.
Old 10-15-2009, 11:29 AM
Could be cooling fan for condensor not working . Driver side vents blowing air out of them at all ? Ducts are controlled electronically . Passenger side vents blowing warm air could still be a duct work problem . Could also be low on coolant or even a stuck open thermostat .
