Old 10-16-2009, 03:00 PM
megahemi's Avatar
megahemi megahemi is offline
Vehicle: 2006 Ram Mega Cab
Color: Inferno Red
megahemi is on a distinguished road
Default Lower 1500 Mega cab
I looked thru the posts & did not see anything about lowering a mega cab. Any ideas on lowering the rear so it's level with the front? (leaf springs & heavy duty suspension).
Old 10-16-2009, 08:08 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
Is axle above or below leaf springs? Above= use blocks, below = use shackles. Thats what I'd do.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 10-16-2009, 09:08 PM
Agreed with that one .
Old 10-17-2009, 01:42 AM
I push the skinny pedal
Rep:3277
You might also look at finding a kit for the 2500 since I believe they're the same chassis. They are few and far between, but I've seen them out there. If you can't find any kits, then go with greg's advice.
Kurtis
Old 10-17-2009, 09:02 AM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
hey make leveling kits for the 2500-3500's that give u the lower stance but can still use the rig for towing cuz they utilize helper springs
Old 10-17-2009, 09:03 PM
megahemi's Avatar
Color: Inferno Red
axle is below springs so i'll check into shackles & 2500 kits. Thanks for the advice.
Old 10-18-2009, 01:12 AM
Rep:3277
Let us know what you find, it'd be good to know for the future. You may have to stop by a suspension shop and see if they have any advice. I've seen lots of slammed duallies so dropping a mega cab should be well in the realm of possibility.
Kurtis
Old 10-18-2009, 01:32 PM
GregInAtl's Avatar
Rep:130
Duallies slam the same way, I've done 'em! Shackles/hangers or flip in rear, springs and spindles/I-beam in front depending on brand of truck. The only difference in the ones I did was the parts were burlier, but the same theories apply, just diff parts. There are no real secrets to lowering, just cost.
