Place your Ad Here!
Old 10-16-2009, 09:23 PM
Hemipwrd's Avatar
Hemipwrd Hemipwrd is offline
Vehicle: 2012 Dodge Ram HEMI
Trim Level: SLT Big Horn
Color: Mineral Gray
Rep:103
Hemipwrd will become famous soon enoughHemipwrd will become famous soon enough
Default Need help with lowering shackles!!!
I have read every post about these things and spent countless hours trying to figure it out. I have heard which ones to go with and which ones not to, also heard that when they say it will drop it 2 inches they really mean 1 inch. So, I just have one question, which is the one to get to get the rear of the truck to match the front as close as possible without having to remove any springs? And with no squeaking issues
Old 10-16-2009, 09:39 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
OK, if the shackle is 2" shorter than stock, it'll drop it 1" because it sits at a 45 degree angle or so to the ground, it isn't vertical. If they claim to drop 2" the will be about 3"-3.5" longer.....same reason. Regarding brand, I would research who has them and what drop they do, then see if they really are different. SOme are heavier gauge steel, but may not be necessary. Some people just over build stuff, but a shackle kinda works...or doesn't in my experience, the RARELY fail, the bushing usually does before the steel.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 10-17-2009, 12:36 AM
Rep:3337
^^ he said it. When it comes to quality, I have to say go with the well known brands, they are well known cuz they deliver quality product that people return to. McGaughy's is a good example, quality and a name of backing their workmanship.
Old 10-17-2009, 08:00 AM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
Remember the companies like DJM and Belltech have been around since the lowrider craze in the mid to late 80's to the present. The best way to eliminate the squeaking is to pick up an energy suspension bushing kit.
Old 10-17-2009, 10:55 AM
SA1911A's Avatar
SA1911A SA1911A is offline
Vehicle: '04 Dodge Ram QC
Rep:14
SA1911A is on a distinguished road
Lowering shackles best way to go on a dodge if all you want is from 1"-1.5"
that's all you'll get from a 2" drop shackle.
Remember most of the squeaks on new suspension parts is due to over tightening of bolts. Torque to 50ft/lbs per dealer - do this when truck is on ground with full weight on it. I advise you re-torque after 500 miles or so as well just in case. Good luck.
"I LOVE MY COUNTRY…
IT’S THE GOVERNMENT I DON'T TRUST"
Old 11-04-2009, 03:09 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
use belltechs (I think?), make sure whatever shackles you get has a notch on one side...I've seen them without and they rub on the leafs and start scrapin material off. Also, grease them up well before installing to prevent squeaks..
