Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
MOPAR DECALS
Old 10-18-2009, 08:21 PM
donniehall1
Default Rear end bearing question
I have a 97 Ram 1500 that has a noise in the rearend. We all believe it is one of the bearings in the rearend. I would like to replace the bearings myself (I have done it before on other trucks and cars) but would like to know if the axle bearings are pressed on the axles or in the end of the axle tubes.
I can handle the axle tubes but I don't have a press if it is needed.
Thanks
Old 10-18-2009, 09:02 PM
In the axle tube . Make sure you check the condition of your axles where the bearings ride . Have seen some wasted axles .
