tonneaucovered.com
Old 10-19-2009, 06:46 PM
martimar23's Avatar
martimar23 martimar23 is offline
Vehicle: 2014 dodge ram larmie
Color: Grey/Silver
Rep:73
martimar23 will become famous soon enough
Default Wind noise
Ok, so after finally getting my truck back from the last fubar, I was driving down the highway around 75 with a slight headwind and I hear this wind noise coming in the passenger side compartment. It got louder the faster I drove. So does anyone have a clue of where it could be coming from?? PLan on taking it to the dealership, however dont think they will beable to reproduce it.
Old 10-19-2009, 07:12 PM
I push the skinny pedal
Rep:3308
I have a wind noise problem in my '07. The doors don't quite seal on the top driverside against the wind. I have no water leaks, but I get lots of noise when I'm driving with a headwind. If I pull on the door then it goes away. Maybe see if the dealer is able to get a wider door seal.
Kurtis
Old 10-19-2009, 07:14 PM
Maybe you'll have to take the service writer for a ride and let him hear it . Alot of times that's what needs to happen so it don't get written off as no trouble found . How did you make out with your headliner getting wet ? Did they replace the headliner ?
Old 10-19-2009, 10:07 PM
martimar23's Avatar
Color: Grey/Silver
Rep:73
I never did get my headliner replaced, since there was no physical damage to it, go figure.
Old 10-19-2009, 10:38 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
I have had a radio antenna "whistle" like a wind noise if it is a smooth shaft. Tie it back with string and try.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 10-20-2009, 04:53 AM
Mohawk's Avatar
Mohawk Mohawk is offline
Vehicle: 2009 Dodge Ram 4X4
Color: White Sport
Mohawk is on a distinguished road
Also, Take a look under the passenger seat.
See the bolt that holds the Jack down?
Look around and I found another threaded Hole that went right thru to open air.
I put a bolt in it to plug the hole. It's a metric bolt.
To check your weather stripping on your door get some paper and cut into strips about 1 1/2" to 2" wide and close a strip in your door, extending out so you can grab it.
Now see if you can pull it out.
Keep moving the strip around your door and checking to see if you can pull it out.
If you can pull the strip out at any place, That spot is a good candidate for an air leak at speed.
The door may be adjusted to increase pressure on the weather strip.
Or the weather strip can be beefed up in that area to help seal the door.
Good Luck
Mohawk
Old 10-20-2009, 04:06 PM
glamontagne's Avatar
glamontagne glamontagne is offline
Vehicle: 2009 Dodge Ram Crew
Rep:55
glamontagne will become famous soon enough
Do you have a bug deflector on the front end? I had this cause whistling on my last truck.
Gary--2009 Black Ram Crew 5.7 Truck Champ Stainless tube steps,Tekstyle Tonneau Cover, LED Interior, LED License Plate Lights, LED Reverse Lights, LED Cargos, 5900k Headlights and Fogs.
Old 10-20-2009, 08:12 PM
martimar23's Avatar
Color: Grey/Silver
Rep:73
Thanks for all the recomendations, I will try them out. I do not have bug deflector on my truck,
