Old 10-19-2009, 09:16 PM
95 1500 4x4's Avatar
95 1500 4x4 95 1500 4x4 is offline
Vehicle: 95 Dodge Ram 1500 4x4
Trim Level: Base
Rep:40
95 1500 4x4 is on a distinguished road
Default Ignition switch
The ignition switch in my truck just quit working today, I can still turn the switch but it's like there's nothing there after it passes he ACC position.
Has anyone ever experienced this problem or changed out an ignition switch before?
I have a feeling that the steering wheel is gonna have to be pulled. I'm a little apprehensive about that because I have never pulled a steering wheel with an airbag before.
Old 10-19-2009, 09:24 PM
Not sure if you have to pull the wheel . You may be able to get at the switch by seperating the column covers . If you have to pull the steering wheel , just make sure the battery has been disconnected for at least 15 minutes before tampering with it .
Old 10-20-2009, 03:44 PM
Trim Level: Base
Rep:40
I don't know whats wrong with it now, I tried jumping the solinoid on the starter and nothing happened.
Old 10-28-2009, 11:37 AM
the1imp the1imp is offline
Vehicle: 1999 Ram 2500
Color: Silvergray
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
the1imp is on a distinguished road
Send a message via AIM to the1imp
I replaced my switch on a 99 2500 take the covers off the you will need a tamper proof hex to remove switch if it's the same as the 99
Old 10-28-2009, 09:05 PM
Trim Level: Base
Rep:40
I took off the cover and seen the hex screws, I read that you still needed to pull the wheel to get the ignition lock cylinder to come out.
Did you replace the Ignition lock cylinder that comes with new keys,or just the switch itself?
I'm going to replace it this Friday and see what happens.
I really like this truck, but in the short time I've had it, I put on tires and a new power steering pump plus a tune up, then the switch went bad. The Ignition lock cylinder alone costs $77., then if I cant do it myself, another $85. to have a locksmith install it.
I'm thinking about runnin it on Craigslist for $1000. and cut my losses.
Old 10-28-2009, 11:48 PM
I push the skinny pedal
Rep:3283
I dunno, I'd keep at it myself, but that's cuz I like to just fix stuff.
Kurtis
Old 11-03-2009, 01:42 PM
slimjim slimjim is offline
Vehicle: 99 4x qc150. 95.250 4x 5.9 gas
Trim Level: sport 150, slt 2500
Color: bl or gy
slimjim is on a distinguished road
Don't be too hard on the old girl, she is 15 yrs old! Tires, tune ups, tie rod ends fuel pumps & other wear items will come up as time & miles go on. If $100 repair makes you want to quit the 15 year old truck, look at a 2010 model.
Old 11-07-2009, 11:04 AM
Trim Level: Base
Rep:40
I was just upset that thing were happening to it one after another, I have repaired it and now I'm happy with the old girl again.
I don't mind putting money into a truck for maintenance or other reasons, I just do not like a money pit. Something that's always tore up or breaking down.
Hopefully she'll be a good one and I 'll start spending money on mods and upgrades instead of replacement parts
Old 11-07-2009, 05:00 PM
Rep:3283
Fair enough, but picking up an older vehicle, I'd be expecting to have a few months of fixing bugs from the previous owner(s). Hopefully you're over that part and can get on with the modding too!
Kurtis
