Old 10-21-2009, 01:13 AM
aolslayer's Avatar
aolslayer aolslayer is offline
Vehicle: 1998 Durango SLT 4x4 Green
Trim Level: custom
Color: Green
aolslayer is on a distinguished road
Send a message via Yahoo to aolslayer
Question 97 5.2 stall!!
for the last 2 months my truck would just cut off and then i put it back in park and turn the key and it start right up like there was never a problem and the last few times it has done it i was going up a incline and after it hit level and let go of the throttle then the truck just stops like i turned off the key and i have to put in park like i said and its like it never happend. i put new plug and wires in sunday. i even put accel plugs in and high end wires to just to try and it still go's on. i dont know if its maybe a water in the disstributer cap like i may have a small crack in it or what so plz help me out with your ideas guy and gals.
98 Durango SLT 4x4
Old 10-21-2009, 07:46 PM
MRRMX MRRMX is offline
Vehicle: 2007 Ram Quad cab 4x4
Color: grey
Rep:12
MRRMX is on a distinguished road
IAC maybe going bad.
Old 10-21-2009, 08:24 PM
Don't think it's water in the cap . Could be a dirty throttle plate .Try cleaning the plate and bore of the throttle body . Make sure you use Throttle plate cleaner . Not carb cleaner . Could also be a bad crank sensor . Crank sensor is at the back of the motor , passenger side , in the top of the bell housing .
Old 10-21-2009, 09:40 PM
I suspect the crankshaft position sensor as well.
