Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 10-23-2009, 01:47 PM
Kens04's Avatar
Kens04 Kens04 is offline
Vehicle: 2004 Ram QC 4x4 HEMI
Trim Level: SLT OFF ROAD
Rep:48
Kens04 is on a distinguished road
Default Drive shaft removal
I want to remove the driveshaft in the lot of the place thats going to balance it to save myself $80. I know to remove the four bolts at the pinion flange and slide the slip yoke out of the back of the tranny. Some info I found on removal says to jack the vehicle, is this necessary? Do I need to have the parking brake off and vehicle in neutral, in which case I would chock the tires?? And I read SOME trans. fluid will come out when I pull the yoke, how much fluid are we talking here? Please let me know if Ive missed anything.
Old 10-23-2009, 04:46 PM
MRRMX MRRMX is offline
Vehicle: 2007 Ram Quad cab 4x4
Color: grey
Rep:12
MRRMX is on a distinguished road
Chock the wheels, set the parking brake, remove the four bolts from the companion flange,
put a catch pan under the tranny end of the shaft, remove the shaft. You may lose some fluid or none at all. Id say alot would be 6 oz of trans. fluid.
Old 10-23-2009, 09:10 PM
Park brake on . May have to pull it in neutral for a second . Be careful , don't need to be reading about someone being killed as truck runs over them while pulling driveshaft . Not a bad idea to also chock the wheels . You may want to have a drain pan also and some tranny fluid available . You may loose some fluid once you pull the driveshaft out . Again be careful . Let us know how you make out . Tom
Old 10-24-2009, 03:24 PM
Kens04's Avatar
Rep:48
Im probably going monday Ill let you know how it goes. Thanks again.
