Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Fuel System
Fuel System All Fuel Discussions. MPG - Mileage - Fuel System Maintenance including Air Filter Replacement.
Old 03-15-2016, 11:20 PM
kswar kswar is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: Big Horn 1500
kswar is on a distinguished road
Default P0456 Code, dealer wants me to replace fuel tank
Hello all, been chasing this problem for the past 6 months. First dealer states issue with ESIM and i believe they changed the canister. Light back on 7 days later. Next, changed gas cap, light back on 5 days later. Take back to dealer, now smoke test shows leak in hose from tank that runs parallel to fill hose, which i witnessed. Replace hose and light back on 5 days later. Back to dealer and now they state its a leak in the fuel tank coming from the check valve so i would need to replace tank at a cost of $1400. Seems very fishy to me. Is that an issue that would throw this code? Thanks!
Old 03-16-2016, 09:47 AM
namretsud's Avatar
Vehicle: 15 BigHorn Ecodiesel
Trim Level: Big Horn CC
Rep:239
namretsud has a spectacular aura aboutnamretsud has a spectacular aura aboutnamretsud has a spectacular aura about
They are probably still blowing smoke. Try a local reputable mechanic. If a tank is necessary get one from an auto wrecker.
Old 03-16-2016, 11:36 AM
ramcares's Avatar
ramcares ramcares is offline
Vehicle: n/a
Trim Level: n/a
Color: n/a
Rep:54
ramcares will become famous soon enough
P0456-EVAP PURGE SYSTEM SMALL LEAK
When Monitored:
With the ignition off, fuel level less than 88%, ambient temperature between 4 C and 43 C (39 F and 109 F), and the fuel system in closed loop.
Set Condition:
As temperatures change, a vacuum is created in the fuel tank and Evap System. With the Evap System sealed, the PCM monitors the ESM switch. If the ESM switch does not close within a calibrated time, an error is detected by the PCM. One Trip Fault. Three good trips to turn off the MIL.
POSSIBLE CAUSES:
EVAP PURGE SYSTEM LEAK
EVAP PURGE SOLENOID
EVAP SYSTEM MONITOR SWITCH
IMPROPERLY INSTALLED ESIM
Old 03-16-2016, 11:58 AM
Default ramcares
So it sounds like you're saying that it wouldn't be the check valve in the tank, is that accurate?
Old 07-09-2016, 11:19 PM
Default fixed!
OK, took to local mechanic through a coworker and they found that it was definitely coming from top of gas tank. Dropped tank and wound up being a small hose that was rubbing on truck frame. $598. Lot cheaper than $1500 for new tank.
