TSBs - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Recalls and TSB's.
Old 09-10-2015, 02:51 PM
paul2112 paul2112 is offline
Vehicle: 2010 Ram
Color: Rugged Brown
Rep:13
paul2112 is on a distinguished road
Default TSBs
Anyone know where you can look up TSBs and the fix for them! Thanks
Old 09-11-2015, 08:01 AM
Rep:1915
TSB's are the fix for a known issue. Is there a particular issue you need to address?
Old 09-11-2015, 08:31 AM
Vehicle: 2010 Ram
Color: Rugged Brown
Rep:13
Thanks,one is for the 2009 steering wander and the other is for the ac door actuator replacement (for the 4th and hardest one,,lol) Thanks again
Old 09-11-2015, 09:26 AM
Rep:1915
There are no bulletins regarding the steering wandering; that's most likely an alignment issue. The actuator should be covered under the K17 recall.
Old 09-11-2015, 09:51 AM
Vehicle: 2010 Ram
Color: Rugged Brown
Rep:13
Ok here's the tsb I'm referring to,,,also, when I called the dealership they told me it was only covered under the 36k warranty,,,so I called the dodge/Chrysler hotline and they told me it is vin specific, I told her it was already done and needs to me redone,,,so sry ur sol,, .....(2010 ram 1500 Laramie ). Thanks again for ur help
Old 09-11-2015, 10:16 AM
Rep:1915
Interesting that this one didn't show up on my factory info until I searched the specific bulletin number. Anyway, since it was already done and an updated part was installed, and you're past the 3/36, it would be done at your expense. When's the last time you had an alignment done?
Old 09-11-2015, 10:37 AM
Vehicle: 2010 Ram
Color: Rugged Brown
Rep:13
,,A few months ago I had the alignment done,,,,Firestone even swapped out the tires for a brand new set,,,,still seams to pull slightly and kinda wander....Also, the ticking noise is coming from behind the actuator, below the glove box... I took this act. Apart and no stripped gears...so I'm left to think its the 4th one at the top,behind upper glove box,,,idk,,again thanks for your help...
Old 09-11-2015, 10:50 AM
Rep:1915
I'd love to see a copy of the alignment numbers if you have one.
Old 09-11-2015, 10:54 AM
Vehicle: 2010 Ram
Color: Rugged Brown
Rep:13
Sure,I'll try and find it, may be a few days,,,also again any ideas on the clicking sound ,and also will this cause the ac to wrk only in the low setting for a period ,then operate normally? I've tried a new blower and resistor...thanks again
Old 09-11-2015, 11:00 AM
Rep:1915
The clicking is an actuator but the blower operation is likely to be a different issue.
