Old 10-24-2009, 07:15 PM
04HemiRam's Avatar
04HemiRam 04HemiRam is offline
Vehicle: 2004 Dodge Ram 1500
Color: Dark Blue
04HemiRam is on a distinguished road
Default 6" lift Questions
Hey I have been putting a little away for a while now and spent hours surfing the net looking for the right lift and tires. It is about time i finally order them but i would really like some questions answered and love some advice. I'm am going to go with the skyjacker 6" lift with 4.5" rear blocks. I will be getting 35" all-terain tires w/ 17" rims. I was wondering what modifications i would need to get this done. So far i have been told re-index the transfer case, re-gear the differential, and reprogram the spedo.
Anything else i should know about? I would truly appreciate any advice you can give.
2004 Dodge Ram 1500 5.7L V8 4x4
Old 10-24-2009, 08:03 PM
If the kit is complete with drop brackets for your steering components, that's pretty much it except possibly having to rotate the front and rear differentials to get the right pinion angle. If they do the transfer case as you mentioned, you may be OK and won't have to do that.
Good luck with the lift!
Old 10-24-2009, 09:07 PM
Suspension or body lift ?
Old 10-24-2009, 10:25 PM
nhegel's Avatar
nhegel nhegel is offline
Vehicle: 2007 Dodge Ram 1500 Mega Cab
Color: Electric Blue Pearl Coat
Rep:31
nhegel is on a distinguished road
You might have to move or replace trackbar. Don't forget an alignment job. Also make sure the kit comes with swaybar links.
Old 10-25-2009, 12:58 AM
jdanthony26's Avatar
jdanthony26 jdanthony26 is offline
Vehicle: 2014 Dodge RAM 1500 crew cab
Rep:38
jdanthony26 is on a distinguished road
check out the pro comp kit,, i put one i my buddies truck and it was very easy to install and i came with everything.. he put a set of 17" with 35x12.50's with a 4.75 backspacing,, everything came in the kit,, he bought it from 4wheelonline.com they will work with you on prices too in you buy all of it. but if you decide to go with that one let me know how it works out for you ... good luck
Old 10-25-2009, 11:25 AM
04HemiRam's Avatar
Color: Dark Blue
Suspension, here is the link to the kit.
http://performancelifts.com/cgi-bin/cart/SKYD2601K.html
lift, re-gear, suspension, tires, truck
