Old 10-24-2009, 11:01 PM
ramster's Avatar
ramster ramster is offline
Vehicle: 1997 Ram 3500
Color: White/Driftwood
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
ramster is on a distinguished road
Angry '97 5.9L 3500 Ram won't start
Pulled the batteries out today and cleaned up all my connections, now she turns over but won't start. Didn't have any trouble before, just doing some Saturday afternoon maitenance. Checked all connections and fuses, I'm stumped.
Old 10-24-2009, 11:03 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
Are your batteries at full charge??? Fully charged batteries are 12.6V...anything lower can cause your car not to start properly...
Old 10-24-2009, 11:08 PM
ramster's Avatar
Yes Sir! Started her up, drove her over by the shop, removed the batteries, cleaned everything up, re-assembled, tried to start, turns over, no start.
Old 10-24-2009, 11:18 PM
Rep:47
Im not a dodge mechanic so just bear with me on these options...You said the batteries are fully charged, connected correctly...Did you try to jump it??? If so, what happened??
Old 10-24-2009, 11:24 PM
ramster's Avatar
No, didn't try to jump it, she turns over normally, very good spin.
Old 10-24-2009, 11:44 PM
Rep:47
I would say its a bad solenoid in the starter, that is not allowing the starter drive to make contact witht the engine flywheel gear that transmits starter motor power to rotate the engine...
Old 10-24-2009, 11:48 PM
ramster's Avatar
Engine turns over fine. No start. Not out of fuel, full tank.
Old 10-25-2009, 12:01 AM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
shoot i don't know since it's diesel.
Old 10-25-2009, 12:56 AM
Doesn't need to be plugged in does it . See your in Colorado . Don't know how cold it is there . Not 100% up on diesels , but know they need a little heat air and fuel . Should start . Next thing I would check , see if you have fuel pressure at the injector while cranking , crack a line loose . If you do (I think your electronic fuel injection , correct) see if you are getting a signal to your injectors . You did say you checked the fuses . Did you check them with a test light , or eye ball them . Don't go by your eye sight , alot of times they have a hair line crack and you won't see it . Let me know how you make out . Tom
Old 10-25-2009, 11:49 AM
ramster's Avatar
No, not cold enough yet. One other time I had a won't start problem, it was a fuel control solenoid. Yes, I just eye-balled the small fuses. The larger ones I did a continuity check. No electronic fuel injection, that wasn't until '98, I have a '97. Any other ideas??
