Old 10-25-2009, 05:28 AM
GunDog1 GunDog1 is offline
Vehicle: 04 Dodge Ram 1500 5.7L H
Trim Level: no clue
Rep:13
GunDog1 is on a distinguished road
Default Looking for power
Ok So Had a crazy thought run through my mind today. I got a 1500 5.7l H. Its a 2004 and is extended cab. I was wondering if I had the time and money would it be possible to make a manual? And run 4.10 gearin.
If not then what should I do to get that power I want out of the truck and get great low end and pullin power? Maybe destroy some vehicals in power now and then?
Basically I'm getting deployed again and Want to beast out my truck.
Gain in horsepower and torc is BIG plus!
Anyhelp is great. Thanks!
Old 10-25-2009, 08:17 AM
08Ram1500's Avatar
08Ram1500 08Ram1500 is offline
08Ram1500 is on a distinguished road
For power, I would go with the DiabloPredator chip, CAI, and exhaust. I personally have a flowmaster exhaust and about to install the K&N 63aircharger. I have read lots of good reviews over the BFI CAI, but it is too expensive for me.
Old 10-25-2009, 08:27 AM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
I def think it would be a waste of money just to make your truck a stick shift...If your looking for whats best out there on the market for the HEMI, you need to be willing to spend the money...For a CAI, i would get the BFI, for an exhaust i would get a MOPAR powered by BORLA exhaust, you could get headers too... and I would prefer getting the Super Chips tuner instead of the diablo because its more for a low profile setup, the diablo will work on low profile setups, but is mainly for SC or turboed engines...Now if you wanna get a SC, thats a different story...But you did say you want to make your truck a BEAST, and a SC will do that...
Old 10-25-2009, 11:04 AM
Lot of work to convert over to a manual trans . Lot of headaches . You'll probably regret even starting the conversion . Only way I would even attempt to do it is if you had a donor truck there for all the parts and hardware . Would go with the Diablosport Predator . Great tuner there for the money .Would also look into headers , high flowing cats , good set of mufflers , cold air intake . Could even go with a set of under drive pulleys .
Old 10-25-2009, 01:15 PM
Trim Level: no clue
Rep:13
I already got the flowmasters and k&N. But for some reason it seems I lost some power. What is BFI, and SC?
K so I will throw the manual idea out lol.
Old 10-25-2009, 01:46 PM
If you opened up your exhaust a bit, you might have lost some low end torque. No worries. Get a DiabloSport Predator and a 180 degree thermostat.
You can always change the diff gears as well with a 3.73 or 3.91 set for a good increase in torque.
Old 10-25-2009, 10:21 PM
raceram9's Avatar
raceram9 raceram9 is offline
Vehicle: 07 Flame Red QC
Trim Level: Sport-R/T
Rep:51
raceram9 will become famous soon enough
no dont get the 3.92 gears if you are going to change them go with 4.10 or even better 4.56 and a superchips programmer headers a plus
2007 RAM QC FLAME RED,20s, 3.92 rear Vararam CAI, Cherrybomb vortex mufflers dumped out in front of rear tires, Superchips Cortex, R/T badges on grill and tailgate custom designed stripes and hood vinyl.....and more to come
Old 10-25-2009, 10:29 PM
I push the skinny pedal
Rep:3277
The BFI is the name of the intake from Airflow Inovations
http://www.ramforumz.com/showthread.php?t=40649
And an SC is a supercharger... if you go that route, then be prepared to fork out for new tires... cuz you'll want to roast them everywhere you can!
For more power after the basic 3, CAI, exhaust, and tuner; then for the low end: long tube headers, highflow cats, and an underdrive pulley to reduce the parasitic drag from your accessories; also a higher lobed camshaft will make some big differences.
After that, if you want to tear into the top end you can get ported/polished cylinder heads w/ big valves.
Kurtis
Old 10-25-2009, 10:40 PM
Superchips is a good system but it's all canned programs, no options for fine tuning, which I use with my 300 SRT8 to set fan on temps, add fuel to reduce a lean condition, getting a CMR dyno tune and a bunch of other options.
I've used Superchips before and liked them but they just aren't as flexible for custom programming as the Predator.
Old 10-25-2009, 11:57 PM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
Why don't you just throw on a supercharger instead? I wouldn't convert it to a 6-speed unless you're deadset on rowing through each gear. Nitrous offers the best bang for the buck, but if you have lots of money to spend I'd recommend an STS twin turbo. Aftermarket intakes and exhausts help a lot too.
