Old 10-25-2009, 11:50 PM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
Default Rear Locking Diff Question
Please excuse this question if it seems rather stupid, but this is my first Dodge truck so I'm not familiar with it entirely. I just wanted to know if there is a way of determining whether or not it has a rear locking differential, specifically an electronic rear locking diff similar to GM's Eaton G80 differential. My truck's posted on my profile, an '03 Dodge Ram 1500 SLT Crew Cab 5.7L Hemi 4x4. The range select is on the floor unfortunately, not the electronic range select that I would absolutely love to have. It has the 20 inch wheel package, if that helps.
Old 10-26-2009, 12:09 AM
Don't believe so , at least not a factory setup . You should be able to check the label inside your glove box and see if it is equipped with a Sure Grip (posi) .
Old 10-26-2009, 12:34 AM
Incognito's Avatar
Rep:72
Ah, so Dodge calls it Sure Grip, eh? Cool. Thanks for the info. I'll take a look!
Old 10-26-2009, 12:58 AM
wakeboardfusion wakeboardfusion is offline
Vehicle: 2006 Dodge Ram
Trim Level: Lamarie
wakeboardfusion is on a distinguished road
can you hear it when you turn really sharp, sometimes you have to hit the gas a little
Old 10-26-2009, 01:25 AM
Incognito's Avatar
Rep:72
Heh heh! I take turns pretty sharp unless I'm hauling the trailer, and I'm always heavy on the gas. Most of the time all I can hear is the Hemi roaring or the Goth music blasting...
Old 10-27-2009, 01:03 AM
Incognito's Avatar
Rep:72
I took a look in the glovebox today. I got a locking rear diff! Great stuff! I also have 3.92 gears, and strangely enough a 5-speed automatic? What the hell? I thought Rams only came with a 5-speed auto this year. Hell, if this is true then I definitely can't complain about having the extra cog.
Old 11-03-2009, 01:21 PM
blackmamba360's Avatar
blackmamba360 blackmamba360 is offline
Vehicle: 2000 Dodge Ram 1500
blackmamba360 is on a distinguished road
hold your foot on the brake and floor the gas if both wheels spin its "posi". if not its a 1 wheel peel.
Old 11-03-2009, 09:37 PM
SD60F's Avatar
SD60F SD60F is offline
Vehicle: 2006 Dodge Ram 1500 Megacab
Rep:25
SD60F is on a distinguished road
Send a message via MSN to SD60F
Where would this glove box sticker be? I looked in my 2006 and don't see one.
Drive a hybrid, I need your gas!
Old 11-04-2009, 11:37 PM
Incognito's Avatar
Rep:72
I just discovered it has a rear locking differential as mentioned in the glovebox. The sticker is right in the glovebox door, right when you open it up. You can't miss it, unless someone removed it.
Old 01-17-2013, 11:27 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
It is not a locking differential (if it is factory)...it is a limited slip differential...big difference.
And the GM G80 isn't electric locking either, it is all mechanical.
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
