Old 11-07-2009, 10:43 AM
drp6982's Avatar
drp6982 drp6982 is offline
Vehicle: 2011 3500 SLT Diesel Dually
Trim Level: 3500 SLT
Rep:185
drp6982 has a spectacular aura aboutdrp6982 has a spectacular aura about
Originally Posted by AIR RAM View Post
2002 Dodge Ram 4.7L with Sullivan Single Plane intake manifold. To date there is NO loss of low end torque but a HUGE gain of top end pulling power. With the Sullivan Intake and only a base SCT tune with 26 degrees of timing advance and an AFR of 12:1 across the RPM range our 5125lb Quad Cab Ram
Wow, Im surprised an intake with runners that long didn't knock your TQ down..... Usually you see top end HP and loose TQ.......
Im glad its working out though, I love reading this thread
My Mopar Stable: 07 SRT8 Charger 426 Stroker with Direct Port Nitrous (1/4 9.70@138.88mph)'
2011 Dodge Durango Crew 5.7L Hemi / Custom Katskinz
2012 Chrylser SRT8 300 optioned Out
2011 Ram 3500 SLT Big Horn Dually
Old 11-10-2009, 12:00 AM
AIR RAM's Avatar
AIR RAM AIR RAM is offline
Vehicle: 2002 4.7L QC RAM (9.49's 8th)
Color: SILVER
Rep:13
AIR RAM is on a distinguished road
Actually its the opposite. Longer intake runners normally enhance low end torque and the shorter intake runners tend to enhance top end HP.
The unique thing about our Sullivan Intake set up is that the intake actually has more volume then the 4" runners in our heads. So our adapter plates taper DOWN which increases velocity... So the last 4" of our intake runners are not changed. This actually helps flow. This same intake on the 4.6L KILLED there low end torque because their intake runner volume (in the head) was higher... this means lower air speed and slow air kills torque. In our 4.7L we do NOT have this dead spot because the runners in our heads have less volume... meaning they INCREASE velocity. So we can get more air past a smaller intake valve.
So we have done two things by adding the Sullivan intake to our 4.7L engine. We increased the runner length of the Sullivan intake by 2.5" with our adapter plates. At the same time our 2.5" plates act as a velocity stack. The runner lengths are approximately 14" long from the floor of the intake to the back side of the intake valve... Mind you its practically a direct shot down straight down. So we have a decent length runner which in theory should give both good top end HP and produce decent low end torque. Then our Intake Adapter plates taper down from the larger Sullivan intake runner volume to the smaller 4.7L intake runner volume. The transition at that point increases velocity in the intake runner as it enters the head and just prior to the intake valve. In a since, we have added a velocity stack 4" above the intake valve. We have the best of both worlds, and I honestly feel we have the perfect intake combination for producing great low & top end power.
This intake will prove to be a killer combination for anyone looking to build the best possible 4.7L engine. Its cheaper then an all out custom fabricated intake which tend to be all top end power & it will out perform them everywhere in the RPM range.
This intake does require custom SCT tuning. It has moves more air up top then your PCM can possibly adjust to. It will cause SUPER LEAN conditions on stock tunes at WOT. This is a testament to its ability to do exactly what its advertised to do... MOVE AIR and allot of it!
SPEED SAFE, AIR RAM
Old 11-26-2010, 12:30 AM
4pnt7 4pnt7 is offline
Vehicle: 2008 4.7l Dodge Ram
Color: Graphite Grey
4pnt7 is on a distinguished road
Airram needs to give an update!!! I see there are a few build going on and there's a Guy running the m112 on his Jeep Cherokee.
Nicolas Chavez
2002 ram 4.7l qc (Totaled),60ft.-2.0,1/8-9.310,@76.mph,1/8-9.41,1/4-14.80,@90.94
Old 11-27-2010, 02:29 PM
RamItAll's Avatar
RamItAll RamItAll is offline
Vehicle: 2002 Dodge Ram 1500
Color: Blue
Rep:85
RamItAll will become famous soon enough
you could've used my truck as a guinea pig to do whatever you wanted to increase HP and TQ. ill throw some airram stickers all over and it and we'll call it even
but really id love to see some updates when you've got them
Old 12-01-2010, 02:40 PM
deerslayer1521 deerslayer1521 is offline
Vehicle: 2003 Dodge Ram
deerslayer1521 is on a distinguished road
wut upgrades are you doin to the top end? heads? cams? springs? adjusters? and will the truck be streetable after you are done?
Old 12-02-2010, 09:09 PM
I'm not sure, but the last time I talked with him his top end was
Race ported heads
H.o cams/comp springs
Airram adapters/Sullivan intake
F&B 72mm throttle body
Hes running Ross pistons and 10.5.1 cr I believe.
I sent him a link to this post, maybe he'll post up.
Nicolas Chavez
Old 12-03-2010, 01:31 AM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
I love to see the 4.7s being built people forget about how awesome the 4.7s are just b/c the HEMI is epic but when compared to other comparable engines by different companies the 4.7 is awesome to! gotta love what airram does
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 12-03-2010, 09:19 PM
just tryin to get some kind of idea bout this motor... im gettin ready to start buildin a NA 4.7 for my truck... and dont have a clue.. wantin to build a BADASS DD.. this motor aint got a lot of info out there.. it aint a tried and true 360 thats been built a million times and got all the R and D to back it up.. oh well gonna be an expensive trail and error session..
Old 12-03-2010, 10:55 PM
There has been a few built 4.7l on different forums. Mostly on Dakotas and jeep grand Cherokees. As far as all the R&D I'm not sure. I'm also wanting a B/A motor.
Its pricey, but I know ill enjoy it. Lol
Nicolas Chavez
Old 12-06-2010, 12:21 AM
southpaw5m's Avatar
southpaw5m southpaw5m is offline
Vehicle: 2003 dodge ram 4.7L
Color: Patriot Blue Pearl
Rep:23
southpaw5m is on a distinguished road
Default Nice!
Hey Nick, Matt here I'm new to this site but have been on airram.com a million times drooling at all the available 4.7L parts you guys have there. What cam do you think would go well with the Sullivan Manifold and race heads with 72mm TB? I also want to put one of the underdrive pulleys on, what size do you think is good, the 6" or 7"??
