Old 10-26-2009, 08:47 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Default Painting Valve Cover Questions.
I've been contemplating painting various parts of my engine, and I am, and I plan to start with the "Valve Covers" I have some concerns though... was hoping you all could help me out here. Anywho:
A. it's all metal, How would I prep it? I saw metal enamels at the store today, but didn't see how heat resistant they were.
B. The whole gasket deal... I hear it would have to be replaced?
and C. Torquing down the bolts to hold it back on... I have also heard that there is a special way to do it or something like that? UGH haha
Here's a shot of what I'm workin' with.
Old 10-26-2009, 09:34 PM
MoparGuy86's Avatar
MoparGuy86 MoparGuy86 is offline
Vehicle: 1985 Dodge D250 5.9 2WD
Color: Faded Gray
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
MoparGuy86 is on a distinguished road
Damn thats a good idea. Have you thought about a color yet or how your going to paint them? Like just the ribs the color of your truck and the depressions like a silver? That would look sick.
Old 10-26-2009, 10:14 PM
The main importance is to make sure you get all the oil residue off . If you can pull them and take to a machine shop and have them tanked . That will remove all the oil from them . Even once you get them back I would still wipe them down with a prep solv . Use a engine enamel primer and paint . Definitely replace the gaskets . Their probably the originals anyway . When I do valve cover gaskets , I always torque them down with a 1/4 inch hand ratchet . That way you know you can't over tighten them .
Old 10-26-2009, 10:17 PM
duggerdugger6 duggerdugger6 is offline
Vehicle: 2000 dodge ram 1500 quad cab
Trim Level: laramie slt
Color: dark blue
duggerdugger6 is on a distinguished road
A) scub the cover with green scotch brite scrubby, this gives the paint a key to stick to. scub till the shine is gone from the black paint. wipe it down with a tack cloth to remove the dust. then wipe it down with prepaint to remove any remaining dust and greese. after the prepaint don’t touch it with your bare hands the oil from your skin will get on it. paint it with a metal primer. sand with 800 wet paper to smooth the primer, tack cloth, prepaint, and then paint with the finish color, probably 2 coats, maybe 3 if you use red. clearcoat it if you desire. as far as I know valve covers don’t get hot enough to need special paint. maybe someone else could help answer that.
B) I have had success in the past reusing valve cover gasgets several times, al long as they were not torn and did not sick to the head. but the covers were not as hard to get to as yours looks in the pic. I would consider going with a new one rather than having a leak.
C) I have not had a leak just tightening the bolts hand tight in a crisscross patter like you would when putting on a tire.
if you twotone it like moparguy86 suggests, I would consider painting it silver (or whatever base color you chose) and hand pinstipping the top of the ribs with a brush. you could try wide pinstrip tape but the heat could take it back off. spraying it with the other color will require a lot more down time and masking it off etc....
Old 10-26-2009, 11:48 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
Thanks for all of the help guys.
Now on a separate note... What else do you guys think would look good painted? I was browsing around and there is some mounts that could be done.
Old 10-26-2009, 11:49 PM
You had to ask about painting something now didn't ya .
Old 10-26-2009, 11:53 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
Who knows, the engine is SO BORING. Yeah it's clean, but the whole damn thing is basically black. There is nothing unique but the headers. Lol
Old 10-26-2009, 11:55 PM
Pink stripes down the freshly painted valve covers . I LIKE IT !
Old 10-27-2009, 12:00 AM
Fast Willy's Avatar
Fast Willy Fast Willy is offline
Vehicle: 2008 Dodge Ram QC
Color: Blue
Rep:31
Fast Willy is on a distinguished road
Send a message via AIM to Fast Willy
Get them powder coating trust me. any bad prep work at all this they will bubble and blister.
Old 10-27-2009, 12:07 AM
98sst's Avatar
Trim Level: SS/T
Rep:883
If you paid me to do it, I would.
Good input. I've been looking for a good part time job for quite a while now, have a feeling that I'll achieve at least an interview within the next 2 weeks at a grocery store.
Hopefully I'll come across more money, people don't go to much winter shows for local bands seeing as most shows are in seattle, miles from anywhere.
