Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 10-26-2009, 10:18 PM
Nick Boudin Nick Boudin is offline
Vehicle: 1994 Ram 1500 slt. Manual 2wd.
Rep:22
Nick Boudin is on a distinguished road
Default Radiator fluid and tons of smoke from the exhaust.
Bad head gasket? Warped heads? Blown block?
There was puddles of radiator fluid on the drive way behind the tailpipes, and it was POURING smoke all the way home. I drove it like that for about a mile or so. IDK?!
Always had problems with massive amounts of oil being burnt off, so I'm assuming it could be anything really. Rings? Heads? Gasket? Blah..
Anyone have tips?
5.2 91k miles 2wd manual tranny.
Old 10-26-2009, 10:39 PM
Using oil was probably bad gasket on bottom of intake manifold . Sounds like a bad head gasket . Pull all the spark plugs out . Fill the radiator with water . Have someone bump the key and see if you have any liquid squirt from the spark plug holes . When doing this make sure you stand in front of the truck or you''ll get sprayed . Let us know what happens . Tom
Old 10-26-2009, 11:10 PM
Rep:22
And if I do this and water does/dosent come out? Whats my outcome?
Old 10-26-2009, 11:23 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
If water does come out, you have a blown gasket...If it does not come out, thats one less thing off the list to worry about...From what it sounds like, thats what you have...
Old 10-27-2009, 01:23 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
using oil and coolant are most likely linked...and it probably is a blown head gasket.
As to which side...idk. Pull each plugs out and look at the color of them, if its one that is getting coolant, it will be noticably different. I believe they turn a rust color....but, I at least know they'll be clean of carbon. And, if its one thats burning oil...well, you'll be able to tell that too.
That'll at least pinpoint what side to check.
Also, make sure there is no coolant in your oil (white on the dipstick). If there is, don't start it again, and drain the oil out immediatley.
Also, check your radiator for oil.
Both can happen with a blown head gasket.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 10-27-2009, 08:01 AM
Rep:47
you can also check to see if there is coolant in your oil by taking some off the dipstick, and putting it on somethin very hot, like headers, and if the oil sizzles then you know there is water/coolant mixed in with it...And yes, a white colored spark plug is a sign of blown head gasket because the engine is overheating...
Old 10-27-2009, 12:55 PM
Rep:22
Sorry, these pictures are from my cammera... One side seems to be noticably darker then the other.
The "white" spark plug is from the left side, and the dirty one is from the right.
Though, the "whtie" one has more carbon build up and the dirty one looks as if there's less or it's "discolored"
No oil in my radiator tho, or coolant in the oil?
Old 10-27-2009, 05:45 PM
Well what did you find ?
Old 10-27-2009, 07:25 PM
Rep:22
I'm not finding coolant anywhere except the driveway. Plugs are dry, looks like none on the dipstick. I do recall hearing a "gurgling" noise behind the glove box as I was accelerating. I also hear that noise on cold mornings, too.
Ideas?
Old 10-27-2009, 07:34 PM
Sounds like it's low on coolant . The gurgling behind the glove box is the coolant being pushed through the heater core .
