Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 10-27-2009, 06:42 PM
Nick Boudin Nick Boudin is offline
Vehicle: 1994 Ram 1500 slt. Manual 2wd.
Rep:22
Nick Boudin is on a distinguished road
Coolant level was fine this past weekend. Replaced the radiator and waterpump within the last 6 months. Hmm..
Old 10-27-2009, 07:23 PM
USAFcrewchief USAFcrewchief is offline
USAFcrewchief is on a distinguished road
well if your only finding coolant on your driveway, look at the bottom of your passenger side door where the carpet ends at, look for coolant. if so then you just have a bad heater core. thats how i found out i had a bad core, discovered coolant dripping from the door.
Old 10-27-2009, 07:30 PM
Rep:22
Never noticed it but the coolant is leaking from the exhaust pipe.
Old 10-27-2009, 07:53 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
yeah, thats def signs of a blown head gasket or cracked block...But, make sure that it is coolant, and not just condensation dripping from the exhaust which is perfectly normal for a good running engine...
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Coolant out of the exhaust usually means its time for a head gasket job.
Sure it'll suck, but it'll make you a man
Old 10-27-2009, 08:05 PM
Rep:22
Puddles of green antifreeze pouring from the tailpipes 4' out to the road when it was running. A cracked block is a possibility? More then likely a blown head gasket?
Old 10-27-2009, 08:10 PM
Rep:47
yeah if its green man, then you know the drill...And yes a cracked block is possible, but not necessarily more than a blown head gasket...
Old 10-27-2009, 08:17 PM
Rep:4072
I didn't see anything on the spark plugs indicative of coolant. The ones I have seen, including some of my own, where the head gasket is leaking leaves a white/ashy looking substance on the plug??? You also said you were blowing lots of smoke. What color was it? White smoke = coolant, purple tends to be symptomatic of bad piston rings...
Old 10-27-2009, 08:22 PM
Rep:22
It was massive plums of white smoke, only thing to do now is a top end tear down... I'll atleast be able to do the plenum aswell..
Old 10-27-2009, 08:23 PM
Rep:47
Well leaking coolant from the exhaust, which he seems sure of, would negate any of those indications on the plugs, or the color of smoke out the tailpipe...Although, you are correct in the description of the two
