Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 10-27-2009, 08:32 PM
Nick Boudin Nick Boudin is offline
Vehicle: 1994 Ram 1500 slt. Manual 2wd.
Rep:22
Nick Boudin is on a distinguished road
The carbon build up on the plugs was present, but nothing looked wet or odd really. Also there was no coolant/water in the oil as far as I could tell. Anything ELSE it could be before I tear it all apart to search for a visable problem? Recomendations on new heads if I need them or a new head gasket/plenum kit?
Old 10-27-2009, 08:43 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
well im sure youll find out about the heads when you get that far, and then you can determine if you need them or not...But the gasket im sure of...Your description of the problems fit the what a blown head gasket, or cracked heads would create...
Old 10-27-2009, 08:48 PM
Rep:47
and if you would like to, and if you are able to...You can always do a compression leak down test, to ensure that the leak is coming from the head gasket...You can do this by applying the air as per the use of the tester, open the radiator cap and if you see bubbles(which would be created by the air), then that increases your chances of having a blown head gasket or cracked cylinder head...
Old 10-27-2009, 08:55 PM
Could have a small crack around the steel ring of the head gasket and is actually being drawn in on the intake stroke .
Old 10-27-2009, 09:15 PM
Rep:22
Either way I've gotta tear it down. Daily driver too, it's too bad. Time to find a winter beater and then start the tear down.
Any recomendations as far as gasket kits or anything?
Old 10-27-2009, 09:59 PM
Rep:47
Sorry man, hope everything goes well though...I pretty sure Tom would know where to get a gasket, rockauto.com i believe...
Old 10-27-2009, 10:02 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
rockauto.com. You have time to wait, gonna need one whether or not that turns out to be the problem. Good Luck.
Sure it'll suck, but it'll make you a man
Old 10-27-2009, 10:04 PM
I like using Fel -Pro products . Nick when you do this , make sure you reseal the plate on the bottom of the intake manifold . May want to consider getting a head set . Should come with everything you need to redo the top of the engine .
Old 10-27-2009, 10:22 PM
Rep:22
Yeah, I'd like to find a kit to do the whole top end but I'm having problems finding a complete kit. I will check out the links you guys sent, thanks agian.
Old 10-27-2009, 10:27 PM
I also think they recommend to replace the head bolts . Have the parts guy verify that for ya . There is a special torque procedure for the torque to yield head bolts .
