Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
tonneaucovered.com
Old 11-01-2009, 05:38 PM
Don't reuse your headbolts . P&P could start at a mild clean up of a couple hundred to thousand dollars if you were all cammed up , lot of compression etc... If you can swing it maybe just a clean up and a little bowl work .
Old 11-01-2009, 09:48 PM
Nick Boudin Nick Boudin is offline
Vehicle: 1994 Ram 1500 slt. Manual 2wd.
Rep:22
Nick Boudin is on a distinguished road
As far as I can tell it was a head gasket failure along with a poor intake gasket and a blown plenum gasket. The blown plenum causing me to burn oil then with my engine being hot because of no oil the head gaskets decided to blow. Somewhere in there the intake gaskets also deteriorated.
Old 11-01-2009, 10:54 PM
When you get it back together , it'll be like a new truck .
Old 11-01-2009, 11:11 PM
Rep:22
Are there any good guides on rebuilding/cleaning heads? I'd like to send them out to be done, but really they dont NEED to be ported or polished.
Old 11-02-2009, 12:08 AM
You should have them checked for cracks and see if their straight . May need to be milled flat .
Old 11-02-2009, 12:42 AM
Rep:22
That'll be my first step. Should I clean them myself? Or just let them do it?
Old 11-02-2009, 12:44 AM
Let them . They do such a better job than we could .
Old 11-02-2009, 12:54 AM
Rep:22
Or should I just have them determine if it's warped/cracked or not and then be on my way and have my dad hot tank them?
