Old 10-27-2009, 10:07 PM
johndeeregreen's Avatar
johndeeregreen johndeeregreen is offline
Vehicle: 1997 1500 4x4
Trim Level: single cab long box
Color: green
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
Rep:15
johndeeregreen is on a distinguished road
Send a message via AIM to johndeeregreen
Default 727 trans question
does anyone know if a 727 trans out of a older 318 bolt up with my 97 318 and transfer case? my stock tranny went out and im haveing trouble finding a replacement but i know someone with a 727 trans for sale
Old 10-27-2009, 10:28 PM
Should bolt up , but not sure of the trans output shaft spline for the transfer case has the same spline or bolt pattern either .
Old 10-27-2009, 10:31 PM
Color: green
Rep:15
ok thanks for the info. anyone know
Old 10-28-2009, 03:59 AM
Johnnyhemi Johnnyhemi is offline
Rep:14
Johnnyhemi is on a distinguished road
there are different style 727s need to figure that out first.... big block or small block 727
spartan max cam,sharadon valvebody,srt10 d60 w/4.10s,hedman LTs,SCT Hemifevertuned,much more
Old 10-28-2009, 05:34 AM
Color: green
Rep:15
im guessing small block considering he had it on a older 318
Old 10-28-2009, 05:36 AM
pwrwgnman's Avatar
pwrwgnman pwrwgnman is offline
Vehicle: 4 trucks
Rep:17
pwrwgnman is on a distinguished road
if its out of a car it wont work, you need one with a short tail shaft, and like mentioned before a big block wont fit a small block, I dont have a clue as to what these new trucks have for a bolt pattern anymore,
Old 10-28-2009, 02:18 PM
Color: green
Rep:15
its a 4x4 out of a older 318 truck
Old 10-28-2009, 06:10 PM
If I'm correct depending on how old your talkin . The older rams transfer case put the front driveshaft out on the passenger side . I don't think it would make any difference as long as you use your transfer case and it bolts up and has the same spline .
Old 10-28-2009, 10:29 PM
Magnum488's Avatar
Magnum488 Magnum488 is offline
Vehicle: 05 1500 4X4 Daytona
Trim Level: Daytona
Color: GoMango
Rep:13
Magnum488 is on a distinguished road
No it won't work. The 97 trans has an overdrive unit which makes it longer than a 727. The crossmember would have to be moved, the front drive shaft shortened and the rear lengthened. The transfer case shifter would need to be modified. The computer wouldn't be happy either, it uses an electronic speed sensor, so no speedo or cruse control etc.
12 Charger R/T R&T, Dynomax, Trinity, 180 stat
05 Daytona QC GoMango 4X4 Long tubes, Y-pipe, Airaid, NX 100 shot, Superchips
03 Durango's 4.7's 4X4's SLT one white one green
95 Ram 1500 4X4 MP computer, shift kit, more..
Old 10-29-2009, 04:53 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
but...as far as bolting up to the motor...yes it would
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
