Interior squeaking? Really annoying. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 10-29-2009, 03:18 PM
bballin1092 bballin1092 is offline
bballin1092 is on a distinguished road
Default Interior squeaking? Really annoying.
There is a squeaking sound coming from either the passenger seat or the middle seat or somewhere in the dashboard. It is really annoying and loud. I have tried spraying lubricant in some spots but hasn't made it better. I think the passenger seat is causing it from moving back and forth from the vibrations while driving. Any ideas how to make the sound stop?
Old 10-29-2009, 03:30 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
What year is your truck? My 2008 has this issue... I had it gone, but it is back, and worse than ever!
Old 10-29-2009, 03:40 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
You know, I just think Dodges are noisy! My Nitro has an assortment of sounds, I just turn up the stereo!
Old 10-29-2009, 03:44 PM
chithead's Avatar
Rep:2078
That did work, but now with 8" speakers in the front doors, turning it up causes more rattles!!!
Old 10-29-2009, 03:46 PM
Vehicle: Blue
Rep:3934
Well yeah! I dynomatted the back end and it still doesn't help. I just learned to live with it and accept it as part of her personality!
Old 10-29-2009, 04:55 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
You sure its INSIDE the truck and not the urethane bushings under the truck, Dodge Rams are notorious for that
Old 10-29-2009, 05:48 PM
Mine is an 08 also and yea Im pretty sure its on the inside because when i hit the passenger seat it shakes and makes the noise. its driving me crazy
Old 10-29-2009, 06:22 PM
mlowney's Avatar
mlowney mlowney is offline
Vehicle: 2006 Ram 1500 quadcab 4x4
Rep:72
mlowney will become famous soon enough
could try greasing the tracks or it could be the recliner hinge thingy. its worth a shot
Old 10-29-2009, 06:33 PM
do you think if i brought it in to the dealership they would be able to do anything about it or no?
Old 10-29-2009, 08:25 PM
Man, squeaks and rattles are the most annoying and hard to fix items out there. I found that my dash defroster panel was rattling and squeaking but it took me forever to find the problem and fix it.
It was more prevalent when it got colder. What I found was some plastic clips on the underside of plastic panel that hooked into some metal studs below them. When it got cold, the metal shrank just enough to create a gap. So I put some electrical tape over the studs, pressed down the panel & clips over them and it worked fine.
Biggest deal is trying to isolate the noise. Hard to do because you have to be in motion. I ended up enlisting my wife's help to listen and put her hands on certain pieces of trim until the noise went away.
Squeaks can be two pieces of plastic trim rubbing together where they join. I've had to get out my razor knife and dremel tool to remove some material in those areas. And I followed the same process with getting some help locating the squeaks as I drove.
So good luck with your rattle and squeak hunt!
