Old 11-02-2009, 12:01 PM
Moes Performance Moes Performance is offline
Rep:31
Moes Performance is on a distinguished road
Originally Posted by rebel2thegrave View Post
Appreciate the info Moe's. I'll be sticking with 2.5" pipe that's for sure.
You're welcome! I lost low end for sure too with the 3". I went back to the 2 1/2" and all my power came back.
Old 11-03-2009, 12:08 AM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
THE EXHAUST MAN SAID THE EXHAUST PIPING IS 2 1/4th inch SO WE NEED THAT SIZE PIPE RIGHT? yes no why do you say so
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
Old 11-03-2009, 12:26 AM
rebel2thegrave's Avatar
rebel2thegrave rebel2thegrave is offline
Vehicle: 2008 Dodge Ram
Color: Brilliant Crystal Black
Rep:65
rebel2thegrave will become famous soon enough
Send a message via Skype™ to rebel2thegrave
I'm guessing the stock pipe on your vehicle is 2 1/4 at the moment... But the size of the pipe all depends upon your engine and what exhaust setup you're running. For starters what vehicle are you questioning about and what engine is in it? Also what type of exhaust setup are you looking at running?
Old 11-03-2009, 01:42 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
x2...it all depends on the engine and the mods on it...for most guys 3" is TOO big (and will lose low-end)..but, with my mods I needed 3" duals to get mine to perform at optimum..
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
Old 11-03-2009, 10:25 AM
Rep:31
Fred, you're right but most guys don't have as much power as you.
I've been told that "as a rule" if you've got less than 500hp at the crank that 2 1/2" tubes are right for true duals. If you have over that then 3".
Old 11-03-2009, 11:47 AM
chefred112's Avatar
Rep:656
that's true..when i was lightly modded I was running single 3" piping to 3"si/2.5" dual out muffler....
compare to now...
back then i thought my exhaust was pretty loud...but now realize it's tame..
