Old 11-01-2009, 03:11 PM
minkandrew's Avatar
minkandrew minkandrew is offline
Vehicle: 1992 power ram w150 4x4
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
minkandrew is on a distinguished road
Default Hard to find harness
Ok i was wondering if someone knew where i could get an engine harness for my 92 w150 4x4 manual trans 1/2 ton multi port fuel injection 5.2L???? I called painless and the local salvage yards and no hits. Please somebody help. WOuld be very apreciative Thanxxx
Old 11-02-2009, 01:37 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Your best shot is to let a couple of salvage yards know what you want. Typically, they cut the harnesses when pulling the engines. Harnesses are not a high value item for them, so unless you get lucky, and a vehicle comes in that is the same, and they know you want one, you're probably out of luck. Had a 98 Merc Villager that had an electrical fire in wiring to the radiator fan. No harnesses available from any dealer, and found out about getting a used one by calling about 30 junk yards. Good luck.
Old 11-02-2009, 05:20 PM
Struck out . No luck . Any good with electrical ? Might have to make your own . If you have a wiring schematic , you should be able to do it .
Old 11-02-2009, 11:05 PM
minkandrew's Avatar
yea i have actually pulled the harness and rebuilt it on my kitchen table, but just seems like i am running into alot of problems such as, timing issues, and other stuff like that. I actually ohm'd each wire to the computer and it all was a good outcome but with any new mpfi electrical system its quite frustrating. thank yous for the advice and i will keep on keeping on
Old 11-02-2009, 11:12 PM
Make sure every connection will be a good tight one . I am starting to see alot of problems with poor connections on alot of new equipment I work on . Let us know how you make out . Keep in touch with us . Tom
