03 dodge brake light problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 11-01-2009, 04:14 PM
j11mmy j11mmy is offline
Gender: Not Specified
j11mmy is on a distinguished road
Default 03 dodge brake light problem
hi guys i have a problem with my 03 dodge 2500 the brake light on cab wont work any suggestions?
Old 11-01-2009, 04:28 PM
minkandrew's Avatar
minkandrew minkandrew is offline
Vehicle: 1992 power ram w150 4x4
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
minkandrew is on a distinguished road
could be the bulb, fuse, or wiring? Probably not the fuse tho beacause its linked to your regular brake lights. pop the cover off and see if the elements in the bulb are broken
Old 11-01-2009, 05:18 PM
i checked the bulb its good also when i step on the brake there is about a 5 to ten second delay before the lights come on so if i have the cruise on same delay before it shuts off
Old 11-02-2009, 03:18 AM
Johnnyhemi Johnnyhemi is offline
Rep:14
Johnnyhemi is on a distinguished road
does it say lamp out on the binnacle, ive replaced brake switches for complaints of brake lights not working or not turning off. Its above the brake pedal behind and under your steering column, you twist it to the left about 90 degrees and it pulls out of its bracket. remove it leave it connected and push it with your fingers and have someone stand behind your truck to tell you if the brake lights are working. If it ever skips or gets stuck, replace it.
spartan max cam,sharadon valvebody,srt10 d60 w/4.10s,hedman LTs,SCT Hemifevertuned,much more
Old 11-02-2009, 06:00 PM
Do the lights light up slowly or just a 5-10 second delay ?
