Rim fit. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8
Old 11-01-2009, 07:11 PM
rapom's Avatar
rapom rapom is offline
Vehicle: 01 dodge Ram 5.2l 4X4
Trim Level: Basic
Color: Green and Black
rapom is on a distinguished road
Default Rim fit.
Will 04 ram 1500 rims fit on a 01 ram 1500? Every thing i find said yes just want to check with you guys.
Old 11-01-2009, 07:20 PM
What are the specs on the '04 rims?
Here's some wheel specs for up to 2003:
1994-1999 1500 2WD/4WD Aluminum Wheels
• Lug Pattern - 5 on 5.5", 1/2" bolt
• Rim Size - 16x7.0"
• Offset - +13.97mm
• Backspace - 5"
• Max Tire Size -
• 15x8.0 rims with 3.5" backspace will fit, but they stick out of the wheel wells.
Torque Spec
• 80-110 ft lbs (108-150 Nm) on 5 stud wheels
2000-2003 1500 2WD/4WD 17" Steel Wheels (Chrome or painted)
• Lug Pattern: 5 on 5 1/2
• Rim Size: 17x7"
• Fits 94 and up 1500 trucks
2000-2003 1500 2WD/4WD 17" Aluminum Wheels:
• Weight: 23.5 pounds
• Rim Size: 17x8"
• Actual width edge to edge: 9 1/16"
• Backspacing: 5 9/16".
• The space from the outside edge to the mounting surface (against the rotor) is 3 1/2".
• offset calculate: 1 1/32"
Old 11-01-2009, 07:32 PM
rapom's Avatar
Trim Level: Basic
Just seen this in my town. Know nothing about them.
http://stgeorge.craigslist.org/pts/1445928225.html
Old 11-01-2009, 11:01 PM
Thats a good looking set of wheels for $200.00 .
Old 11-01-2009, 11:18 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
the 2004 rims (20s I suppose?) will fit your truck. You just have to remove the little center cap so the front hub can stick through.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 11-04-2009, 02:18 PM
Nick Boudin Nick Boudin is offline
Vehicle: 1994 Ram 1500 slt. Manual 2wd.
Rep:22
Nick Boudin is on a distinguished road
You may need a 1/4 inch spacer for the front if your truck is 2wd. For some reason the 20s I have couldent reach the back of the spindle. 1/4" spacer worked perfectly. I got mine at pepboys.
