Old 11-02-2009, 12:49 PM
Travis Travis is offline
Vehicle: 2014 Ram 2500
Trim Level: Outdoorsman
Travis is on a distinguished road
Default Tire size for truck with 3 inch lift
I have a 1999 dodge ram quad cab. The truck is an automatic with a 3 inch suspension lift. The trans has been rebuilt and it has 3.55 gears. The truck has the stock 245/16 tires on it. I want to go bigger, but I don't want to kill all the power, or the trans. What would be a good size to get to fill up the wheel wells. I am kind of looking at 17 inch wheels
thanks,
Travis
Old 11-02-2009, 01:29 PM
I push the skinny pedal
Rep:3308
Well, if you have a 3" lift already then you're primed to fit a set of 35s under there to fill in the space. If you do up to the 35s then I'd recommend going with a 3.90 gear. You can also go with the 33s but they look a little small with a 3" lift, IMHO.
Kurtis
Old 11-02-2009, 03:21 PM
Right now I will probably stay with the 3.55"s so would 33's work well with those gears?
Old 11-02-2009, 04:51 PM
I have 4.10's in mine and have 35's with a 2" Daystar leveling Kit . Little flat from a dead stop . So yeah 35's with 3.55 , would be a snail .
Old 11-02-2009, 05:17 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
is that the family pet!! does he bite?
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 11-02-2009, 07:00 PM
Wanna find out ?
Old 11-02-2009, 07:37 PM
Rep:3308
LMAO, where do you find these things tom? I wouldn't be surprised if you actually had a guard snail...slime the bad guys to death...
Kurtis
Old 11-02-2009, 08:17 PM
What size tires would be decent on it with the 3.55 gears? I don't want to go to 35's. Would 33's be real bad with 3.55 gears?
Old 11-02-2009, 10:37 PM
From the way I've been taught , gear ratio is based on a 28 " tall tire . So if you have a 30" tall tire in reality you're not really running a 3.55 . It would really be less . I would have to quess in the 3.4 range . So with 3.55 and a 33 inch tall tire what are you really running . (I know theres a formula out there) Wild quess , low 3.-- range , maybe in the upper 2.-- You just don't need to put to tall of a tire on it and knock your self out of your power band . I think 33's should be fine .
Old 11-12-2009, 07:10 PM
Ramrob Ramrob is offline
Vehicle: 1999 Dodge Ram 1500 5.9L
Rep:75
Ramrob will become famous soon enough
33's look way too small. They only way they look descent is if the offset on the wheels is enough to bring them out a little. From a side view it looks a little funny.
