Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
tonneaucovered.com
Old 11-03-2009, 11:12 AM
GrassfireBob GrassfireBob is offline
GrassfireBob is on a distinguished road
Default Convert to dual zone heat/air
Hello,
I have an SLT with standard single zone heat/air. I love my truck with the exception of wanting dual zone heat.
Here's my question: Has anyone ever tried to retrofit dual zone into an SLT?
I know it would require a new HVAC assembly unit, new control head, wiring between the two, and completely removing the dash to do it, but I'm up for that. (I replaced the HVAC assembly on my old '95 Dodge once - lots of work but doable).
->> What I don't know - would the wiring harness work? <--
I'm thinking of hitting up junkyards for the parts.
Anyone tried this? Any advice?
Old 11-03-2009, 04:21 PM
LYC79's Avatar
LYC79 LYC79 is offline
Trim Level: SXT CRD 2.0 / 2.8
Rep:426
Sorry I don't have an answer for you but I'm sure that someone with better knowledge than me will chime in soon.
Just wanted to say "hi" and welcome aboard!
Old 11-03-2009, 05:09 PM
Can't help ya there . Don't forget you also have to deal with the airbags when you do this job . Gonna be alot of work even if it's even doable .
Old 11-06-2009, 09:54 AM
mlowney's Avatar
mlowney mlowney is offline
Vehicle: 2006 Ram 1500 quadcab 4x4
Rep:72
mlowney will become famous soon enough
most of the up grade is the indepndet doors and controls. you'r best bet is to hit up a junk yard and find the hole set up that way it is more it is more pug and play. You will need to remove the hole dash, steering wheel and colum as well as draining the coolent and the a/c. the plenume box has to come out no matter what. good luck. Maybe do a write up on it and post it on here
dual zone, heater, hvac
