Place your Ad Here!
Old 11-05-2009, 02:55 PM
mlowney's Avatar
mlowney mlowney is offline
Vehicle: 2006 Ram 1500 quadcab 4x4
Rep:72
mlowney will become famous soon enough
Cool
some times i can find some good info i try to help out any way i can thats why we are all here after all
Old 11-05-2009, 04:34 PM
Originally Posted by Kens04 View Post
Hey mlowney, thats some great info. you dug up. A recap on my vibration, the rebalancing took care of the problem. I wrote more in detail about the experiance in the thread driveshaft weight fell off. I would say start the process of elimination with the cheapest possible fix and continue on from there. Good luck
Great to hear that took care of it .
Old 11-07-2009, 09:18 PM
Megacab07's Avatar
Megacab07 Megacab07 is offline
Vehicle: 2010 Ram 1500
Megacab07 is on a distinguished road
I have an 07 1500 with the same problem. Only difference is that the vibration(entire cab) occurs between 60 and 64 mph. New tires, alignment, no fix. Might look into the offered suggestions. Great site with terrrific input.
Old 03-04-2010, 05:23 AM
gmag69's Avatar
gmag69 gmag69 is offline
Vehicle: 2007 Dodge ram quad cab
Trim Level: Big Horn edition
Rep:18
gmag69 is on a distinguished road
I have a problem with my Ram similar to this. When I hit the brake at around 60 mph the front shakes so bad it feels like the driver's side tire is going to come off. Any other time it is hardly noticeable or doesn't shake at all. I was thinking it may be ball joints or a bad tie rod but I tried checking them when I replaced the anti rattle clips that some decided the truck didn't need at the last brake job and there was no play in either. What do you guys think? I'll check the control arm for movement. It scares the hell out of me I tell ya what.
Old 03-04-2010, 05:41 AM
02BlackSLT 02BlackSLT is offline
Vehicle: 2002 Ram 1500
Trim Level: Quad Cab
Rep:28
02BlackSLT is on a distinguished road
I have this same vibration and was about to start a thread. No need, if you dont mind I will piggy back on this one. My vibration occurs at 55 MPh and its not tire related. The U-Joinst seem ok as well. Any Help would be appreciated.
Old 03-04-2010, 05:42 AM
Rep:28
Sounds like Rotors.... Id get them shaved or replaced.
Old 03-04-2010, 09:48 AM
Kens04's Avatar
Kens04 Kens04 is offline
Vehicle: 2004 Ram QC 4x4 HEMI
Trim Level: SLT OFF ROAD
Rep:48
Kens04 is on a distinguished road
Well guess ill recap on mine too, rebalancing the driveshaft helped but seemed to isolate the vibration to a different tune. So although getting the driveshaft helped I guess I had more than one issue. Mine is a tight vibration at almost any speed, I feel it in the steering wheel, and consol where my hand/arm is. Its mostly noticable at highway 55-60mph speeds and sort of fades and gets stronger fades and gets stronger about every second. Ive been dealing with this all winter and has gotten slightly but progressivly worse. I will start by having the tires rotated and balanced and maybe even take them off myself and clean the insides of them really good.
Old 03-04-2010, 09:55 AM
Kens04's Avatar
Rep:48
Sounds like warped rotors to me also. Trying getting them machined, although they will probably warp again from the heat and you might just be better off getting some new performance rotors and pads.
Have you had work done to eliminate the possibility of tires? I only say that becasue you say its not tire related with certainty.
Old 03-05-2010, 02:39 AM
Rep:28
Have you had work done to eliminate the possibility of tires? I only say that becasue you say its not tire related with certainty.[/QUOTE]
Ok...I took the truck in today, had all 4 tires re-balanced. I just got a set of 20's put on recently. I had the same vibration with the 17's that were on their prior to the 20's, and I always just thought it was the tires. Today I had the 20's road forced balanced and it could be just me, but I think its worse now. Ken the vibration I have is exactly what you describe.
It definately think its drivetrain related. Im going to try u joints next.
Old 03-05-2010, 09:29 AM
Kens04's Avatar
Rep:48
It definately think its drivetrain related. Im going to try u joints next.[/QUOTE]
Oh wow, then yeah your right what are the chances of it being tires when you have done ALL that. I got two opinions on my ujoints a few months ago and said all was good, but havent had the tires balanced yet (which hopefully will be this weekend). Then again I think only joints that were checked were from the tranny back, and I feel like the vibe is coming from the front. 02blackSLT keep in touch even if its a PM and I will do the same since it sounds so similar of an issue.
