Old 11-04-2009, 08:45 AM
Capt JJ's Avatar
Capt JJ Capt JJ is offline
Vehicle: 2004 Dodge Ram 4x4
Color: Two tone Blue and Silver
Capt JJ is on a distinguished road
Default Plugs, plug wires and oil advice
I'm looking to change the plugs. Should I stick with the OEM plugs? I have 73,000 miles. How often should the plug wires be changed? Also, should I start using synthetic oil? What are the advantages of doing so? Thanks for all help and suggestions.
Old 11-04-2009, 01:18 PM
Kens04's Avatar
Kens04 Kens04 is offline
Vehicle: 2004 Ram QC 4x4 HEMI
Trim Level: SLT OFF ROAD
Rep:48
Kens04 is on a distinguished road
I think you cant go wrong with NGK plugs, not sure on the wires, mine say mopar on them so not sure if this is stock or someone put them on before I bought the truck. I changed to synthetic at 96k miles and very happy I did, no leaks.
Old 11-04-2009, 03:41 PM
Lil Black 4x4 Hemi's Avatar
Lil Black 4x4 Hemi Lil Black 4x4 Hemi is offline
Vehicle: 2008 Reg. Cab/Bed 4x4
Rep:70
Lil Black 4x4 Hemi will become famous soon enough
Send a message via AIM to Lil Black 4x4 Hemi Send a message via Yahoo to Lil Black 4x4 Hemi
I can't comment specifically on the plugs/wires but I will say it's hard to beat Bosch, but ther are many FINE plug manufacturers out there.
On oil it's pretty personal in my opinion. The biggest part is changing it regularly. I knew a mechanic that did hot rod-OEM rebuilds and he always said that he'd have been out of a job if people changed their oil like they were supposed to. True to form I've got a Mazda 626 with 310k on it that runs like a top.
On my ram I run the Advanced Auto oil (cheap Shell I think) and a Pure One gold gripper filter. It appalls my bro-in-law but I change it in 3-4k.
Luke
K&N Cold Air Intake, Magnaflow Exhaust, Rancho RS5000s, TRUXXX Leveling Kit, Heavy Duty Towing Shackles, Recon Smoked Cab Lights, Chrome Fender Flares, Stainless Door-sills, Chrome Door Trim, Atturo Trail Blade 35x12.50R20, METAL Grille Inserts.
Old 11-04-2009, 04:48 PM
I personally try to do a major tune up every 60,000 miles including wires . NGK plugs are excellent plugs to use . But you can use the original equipment also . Synthetic is a fine oil to use . I run Amsoil synthetics in all my cars motor and transmissions .
Old 11-05-2009, 12:11 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
Amsoil is bloody expensive, but yes synthetic is the way to go. I use Mobil 1 synthetic on everything I have, including my motorcycles. I would recommend both NGK and Bosch, but I would stay away from any spark plug with more than one electrode. You pay a significant amount more and probably wouldn't notice the difference other than the new-found shrinkage in your wallet. As for wires, I'd recommend going with NGK or Bosch wires as well. You can try other manufacturers but those are two companies I've used over the years and I've never had a problem with them.
Old 11-05-2009, 01:44 AM
I push the skinny pedal
Rep:3277
I'd make the switch to synthetic. I also run Amsoil in the engine and i'm just about to switch the diff and tranny over too. I third the Bosch plugs/wires.
Kurtis
Old 11-05-2009, 02:32 AM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
I use NGK 5306 plugs, Taylor shorty wires, and Mobil 1 oil.
Old 11-05-2009, 06:45 AM
Amsoil is expensive but no more expensive than any other oil out there . Amsoil products you don't have to change as often as you do other oils . The grade of Amsoil that I use , I don't change out until I have 20,000 - 25,000 miles on it . I just make sure I change the filter every 5,000 miles still . Heres their link for more info . www.amsoil.com
Old 11-05-2009, 10:38 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Try these for wires. Most reasonable set of 8mm wires I've found.
http://www.summitracing.com/parts/SUM-867815/
Old 11-07-2009, 02:33 PM
Incognito's Avatar
Rep:72
Amsoil here is about $2.00 to $4.00 more per litre than Mobil 1. And Mobil 1 is the same, states that you don't have to change it for about 20,000km or so. I use my trucks for severe duty, so I wouldn't trust not changing my oil for that long. I change the filter every 5,000km and the oil every 10,000km. It's all very expensive, but at least I know my Hemi is running top notch. Too bad my Cummins isn't.
