Old 11-04-2009, 10:42 AM
Travis Travis is offline
Vehicle: 2014 Ram 2500
Trim Level: Outdoorsman
Travis is on a distinguished road
Default Dumb question....4x4...
I have a 99 dodge ram quad cab, automatic. All the other trucks that I have had have had a manual trans, so the automatic is new to me. The problem that I am having is, the truck will shift into and out of 4x4 high great, no grinding or anything, it will also shift into 4x4 low range fine. The problem happens when I try to shift out of 4x4 low range. The transfer case will grind really bad, trying to go back into 2 wheel drive. I guess my question is, what gear to I put the trans in to shift it out of 4x4 low or does it matter? I didn't know whether to put the truck in park, neutral, or if i should leave it in drive and have the truck rolling to shift it back into 2wd. Any help would be great. I don't have the owners manual to this truck, and it doens't give much info on the back of the visor. I tried to do a search on here, but couldn't find anything that would help with this problem.
Thanks,
Travis
Old 11-04-2009, 01:32 PM
Sport Sport is offline
Sport is on a distinguished road
Park or neutral
Old 11-04-2009, 02:55 PM
mlowney's Avatar
mlowney mlowney is offline
Vehicle: 2006 Ram 1500 quadcab 4x4
Rep:72
mlowney will become famous soon enough
yah on the autos it needs to be in nutral to engage and disengage 4x4 lo
Old 11-04-2009, 02:59 PM
I push the skinny pedal
Rep:3277
^^ agreed. If you have any problems with it shifting out you can always put it in reverser and back up just a tad to get the gears to synch out. But this is a temp fix.
Kurtis
Old 11-04-2009, 03:16 PM
ok i will try that. It only does it when I am wanting to go from 4 low back into 2wd. Going into 4 low, and in and out of 4 hi is fine.
Old 11-04-2009, 04:37 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
This is what I always did, neutral for engage/disengage, then would put it in reverse to make sure.
Old 11-04-2009, 06:10 PM
Should have the tranny in park . Can't move the shifter into 4x4 low range like you can for high range . If you could , you would have alot of people out there with blown motors , transmissions and who knows what else . Can't shift on the fly in or out of 4x4 low . Might want to see if on the backside of your drivers side visor has the instructions on 4x4 operation .
Old 11-06-2009, 11:39 PM
crg1987 crg1987 is offline
crg1987 is on a distinguished road
The owners manual for my 99 quad cab states that you can put the truck into 4-hi up to 35 miles an hour (i've never done it going that fast cuz i'm afraid to) and that it'll go into 4-lo doing less than three. I pull it out of 4 hi/lo while coasting in drive. I used to stop and put in neutral to put it into/out of 4 wheel drive and it clunk and shudder every time. now when i'm rollin its nice and smooth. Guess I'm the oddball here.
Old 11-07-2009, 10:45 AM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
I've always changed on the roll. less than 3mph - 4 lo.
Old 11-12-2009, 11:22 PM
ramz267's Avatar
ramz267 ramz267 is offline
ramz267 is on a distinguished road
put it in nutruel and it should be fine but make sure you use your fourwheel drive in low and high to keep the bareings good
Copper orange RAM 1500 4x4 (larrime) 5.7l hemi!
'Orange Thunder'
