Old 01-18-2010, 05:12 PM
kwatson's Avatar
kwatson kwatson is offline
Vehicle: 2006 Dodge Ram 1500 SLT QC 4X4
Trim Level: SLT Quad Cab
Rep:24
kwatson is on a distinguished road
I've done it at 60 no problem. But that was in my '94.
Kurt Watson - Deer Park, WA
2006 Dodge Ram 1500 SLT 4X4 quad cab
Old 01-18-2010, 05:15 PM
kwatson's Avatar
Rep:24
I do know that you want to make the shift from 4hi to 4lo and back quickly, without stopping the transfercase selector in the neutral position or it will grind. then the best thing to do is shut off the engine and finish the change, then start it back up.
Old 01-18-2010, 06:14 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
havent seen a recent reply................i was woundering how you are making out with this.
Old 02-18-2010, 07:50 PM
Travis Travis is offline
Vehicle: 2014 Ram 2500
Trim Level: Outdoorsman
Travis is on a distinguished road
I partially have the truck torn apart right now. I am getting ready to put new endlinks, and bilstein 5100 shocks on, trans has been rebuilt, and going to put a 360 down in it with a CAI and some shorty headers I believe. Also, it will be getting a new paint job. As soon as I get it back together, I will try some of the suggestions on here. When the trans was rebuilt, the transfer case was also gone through to make sure everything was working correctly. Is it possible the shifter needs to be adjusted on it?
Old 02-18-2010, 07:51 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
there are no dumb questions
Old 02-18-2010, 09:37 PM
ramcharger32348 ramcharger32348 is offline
Vehicle: 2004 Dodge3500 4wd
Trim Level: Lamarmie
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
ramcharger32348 is on a distinguished road
I am not familiar with the 99 but you did not say if you turned a knob or pulled a floor shifter. All transfer cases go into neutral when going from hi to low or low to high. If you have your transmission in gear, as soon as you move the lever from low towards high you hit neutral and the trans will spin the input shaft and thus the gears are not meshed and they grind. Make sure you have unwound the drivetrain, put the trans in neutral, slowly rolling can help, go into hi, put trans back in gear. Then go to 2wd. Been four wheelin for years. Play with it. You'll learn what works best.
