Old 11-04-2009, 09:02 PM
I push the skinny pedal
Rep:3308
Default How much fluid in our diffs?
Hey guys. With this next upcoming oil change I'm gonna swap out both diffs to AmsOil. I was wondering how much I need to swap out both diffs, since I've never actually done it myself before. ANd how much in the tranny if you happen to know? May as well go FULL syn instead of just the engine.
Kurtis
Old 11-04-2009, 10:25 PM
Different years , different motor sizes , different series of trucks require different amounts . Best bet is to check owners manual .
Old 11-05-2009, 12:44 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
6.25 Litres in your tranny, assuming you're dropping the pan and replacing the filter. If you flush your entire tranny then it'll obviously require more, but I can't find that info anywhere. Synthetic is the best choice, always. As far as the diff fluid, I'm certain you simply fill it up to the point it leaks out of the fill hole.
Old 11-05-2009, 02:50 AM
Rep:3308
I just need to order the gear oil so I was just needing to know how much I actually need to order. Guess I'm gonna have to ask the local parts source and see if they know, or just flip through the Hanes book and see if it's there.
Kurtis
Old 11-05-2009, 04:10 PM
Amsoils website can help ya . You can look it up on there .
