Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 11-07-2009, 07:54 AM
sherfield2002 sherfield2002 is offline
sherfield2002 is on a distinguished road
Default Heater problem
I just bought a used 02 Ram and the heater isn't working like it should. When I first turn the fan on it will blow hot air for about 5 seconds then it cools off. If I turn the fan off for a few minutes and turn it back on, the same thing happens. The a/c works fine, just not the heater. Any ideas what might be the cause?
Old 11-07-2009, 08:11 AM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
That could be a few things...Coolant could be bad(or low level), air in the coolant system, bad thermostat, heater core...
Old 11-07-2009, 08:14 AM
The engine does reach full operating temp, if that helps anything.
Old 11-07-2009, 08:44 AM
Rep:47
Its still possible that the themostat is bad(in this case possibly stuck open), even though the truck reaches N.O.T. causing your case of just blowing the cold air...Check the hoses that run from the thermostat, and the heater core to see if they are hot or cold...They should be hot(or fairly warm anyway)...Now if your coolant is at the proper level in the RAD and reservoir(without any leaks from hoses, and the RAD), the thermostat is working properly and its still blowing cold air, check to see if you have a leak inside your truck or a strong smell of coolant coming through the vents, then thats a good indication of a bad heater core...
Old 11-07-2009, 09:29 AM
dodgeman70592's Avatar
Trim Level: Custom
Rep:1648
Good info right there ^^^
Old 11-07-2009, 10:22 AM
ya its a hemi03 ya its a hemi03 is offline
Rep:23
ya its a hemi03 is on a distinguished road
Send a message via Skype™ to ya its a hemi03
yeah my dad was having the same problems with his 02 4.7 and replaced the thermostat and everything come to find out he needed his hoses flushed you could try that or even new hoses. that was all right around 80k to 85k miles
Old 11-07-2009, 11:42 AM
The coolant looks good and I topped it off this morning, it was about .5-1in below the cold fill line. I'll crank it later and let it get up to temp and see if the hoses are warm later. I haven't noticed any leaks or coolant smell in the cab or from the vents.
Old 11-07-2009, 11:56 AM
Do you hear the air diverter valve switching positions when you change from heat to defrost to bi-level?
If not, the little valve in your HVAC distribution box is sticking, the valve may be defective or there's a connection/electrical problem there.
That HVAC distribution box is under the dash.
Old 11-08-2009, 10:41 PM
I think it may be the blend door. I know my mode 1 door is broken, air only blows from the vents no matter what the setting is. I suspect the blend door is broken too. I don't hear it change when i change from cool air to warm air, but i can get warm air briefly though so I'm not sure whats happening.
Old 11-09-2009, 12:13 AM
Could be a blend air door issue or even a partially clogged heater core . Might try clamping off the heater hoses , removing them from the heater core , then take a garden hose with good pressure and flush the core with water back and forth between both nipples . Reinstall the hoses and see what that does for ya .
