Whistle noise inside cab @ 50mph and up - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-08-2009, 11:07 AM
longbow longbow is offline
Vehicle: 2012 Dodge Ram 1500
Color: Molton Red and Silver
Rep:37
longbow is on a distinguished road
Default Whistle noise inside cab @ 50mph and up
Help here ,!!!!
I have a whistle noise problem interior of my cab at 50 mph and up , and gets louder as you go faster. Sounds like it is coming from the center windshield area and is bloody annoying . Can anyone help shed some info on this ??
Old 11-08-2009, 12:03 PM
Check for a loose piece of trim or a gap in your windshield seal gasket.
Old 11-08-2009, 08:38 PM
tjcin's Avatar
tjcin tjcin is offline
Rep:25
tjcin is on a distinguished road
Are you talking about the helicopter type noise if only some of the windows are down? If you are, there is mention of it in the owner's manual. You just have to crack another window and it will subside.
Old 11-09-2009, 01:56 AM
Rep:3347
If you have a CAI then you can get a whistle from there, but I'd say most likely is a small gap in the windshield striping. If you haven't noticed any water running in then it's most likely on the bottom. have a good look at the inside and outside and look for a gap. Also, if you can get a compressed air can and have someone spray the windshield and try to feel a breeze on the inside.
Old 11-09-2009, 02:13 AM
Ramdude22 Ramdude22 is offline
Ramdude22 is on a distinguished road
Mine does the same thing. I think its coming from the antenna.
Old 11-09-2009, 10:45 AM
Rep:37
Exclamation Whislte noise -It becomes painfully loud at 75mph and up
It gets louder as I accelerator, then even with the throttle off it stays the same . Sounds more like when you have a window not fully closed .
I've taped off the sunroof and the top of the windshield and still no change
I had a friend out with me yesterday and he figures it maybe air coming inside the cab somewhere in the center lower windshield area . That could mean anything that is on the firewall, air intake cowl on,the HVAC system or even a pinhole leak at the bottom of the windshield itself
I'm taking it to the dealership today
Old 11-09-2009, 02:34 PM
Rep:3347
Keep us in the loop longbow. Which dealership you going to?
Old 11-10-2009, 12:46 AM
Rep:37
Thumbs up Dealership responds positive results
Went to the dealership today and arranged for an appointment for Thurs. They will do a pressure test to find the problem . I had the service manager out on the road with me today and he could hear the whistle , one good point, he has the same model year as I and so he is very interested .
I will update you all later this week.
Old 11-13-2009, 09:20 PM
Rep:37
Default Problem solved
It is as you said on the passenger side , the down side rubber trim was lifting at high speed . They reinstalled and glued down test drove at 75 mph and no noise .
I must say the dealership went out of there way I am very satisfied with the outcome
