Old 11-08-2009, 10:58 PM
MTtruckr's Avatar
MTtruckr MTtruckr is offline
Vehicle: 2009 Ram 5.7L
Trim Level: Big Horn Package
Color: Stone White
Rep:50
MTtruckr will become famous soon enough
Default Mufflex 18" Install problems
So I just put on my Mufflex 18" the other day but have some questions. It seems that the driver side tip is sitting lower than the passenger, and both seem a bit lower than with the original muffler. This seems fairly strange to me seeing as both pipes are the same and they have all the same hanger assembly; the only difference is the hanger provided by mufflex at the exit of the muffler.
Any thoughts on how this happened? Installation error on my part is possible, I won't get my feelings hurt.
Thanks
BDS 6 inch. Fox 2.0 rear. Toyo MT 35x12.50x18. Yukon 4.56's. Detroit Truetrac. Mufflex 18. Airaid CAI.
Old 11-08-2009, 11:06 PM
Pipes that you hooked the new muffler and pipes up to didn't twist on (or drop ) ya , did they . Could swing down making the fit look poor . Might try loosening up the clamps and have a second person twist them into place for ya while you secure the clamps .
Old 11-09-2009, 08:01 AM
MTtruckr's Avatar
Color: Stone White
Rep:50
Yeah, that was my thought too. I just did that last night. The passenger has some play in it but the driver side doesn't want to adjust at all. It seems maybe the angle the muffler is hanging at could be off causing the exhaust pipe/muffler interface to be incorrect?
Does anyone have any pictures of their mufflex muffler (with dual exits) installed so I can get a comparison?
Old 11-09-2009, 08:15 AM
fuzzycali's Avatar
fuzzycali fuzzycali is offline
Vehicle: 2009 Dodge Ram
Color: Stone White
Rep:63
fuzzycali will become famous soon enough
how does it sound? this is a direct bolt on right?i hope u get this resolved.
Have a dropped RAM? Want too? Join our group.
Lowered RAMZ Owners Club/Houston Area RAM Owners Club
At some point the mod list gets too long.
Old 11-09-2009, 10:59 AM
rjc799 rjc799 is offline
Vehicle: 2009 QC SPORT
Color: Sunburst Orange
Rep:121
rjc799 will become famous soon enoughrjc799 will become famous soon enough
I just installed the 14" on mine yesterday and had to have my wife hold the pass side one while I tightened it. I originally twisted the mufflex until the driver's side one was aligned as well. It just takes two people to do and get/look right.
2009 RAM QC Sport "Sunburst Orange"- Debadged; 4/5 drop; staggered 22s; speedstur tonneau; mufflex 14", limo tint
Painted: headlights (black with body color trim), interior, grill shell, ram head logos, windshield emblem, rim inserts & air filter cover
LOTS TO COME...
Old 11-09-2009, 06:21 PM
MTtruckr's Avatar
Color: Stone White
Rep:50
rjc799, were you able to adjust the driver side at all. I had someone doing the same for me as your wife, but I had no give on the driver side to do any adjustment. I'm wondering if the hanger they provided is aligned a little off. I had to really work to get the muffler exits to align with the hanger clamps. If it is indeed the hanger being too high, I suppose that would explain the exhaust tips ending up too low. Am I totally off here??
fuzzycali, to answer you, yes this is a bolt on...besides from my little hitch it is a slick setup. I really like the sound, check out you-tube for some good clips on this system.
Old 11-09-2009, 08:05 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
The chrome tip is adjustable. All you do is loosen the bolt on the swivel clamp and it will move to where you need it for perfect alignment in the cutout. I think you could even make the tips line up to a bumper without cutouts, there is that much adjustment. The most important thing to do is first align the tip lengths to be the same and make sure that the pipes have plenty of clearance around them to the spare tire, ect. Then align the tip in the cutout by loosening the swivel.
The swivel is about 12-18" forward from the tip. The torque spec for the swivel clamp is 19 ft lbs. Be sure to keep the tip drain hole on the bottom. You can rotate the pipe in the swivel as well as change it's position in the cutout.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 11-09-2009, 09:48 PM
MTtruckr's Avatar
Color: Stone White
Rep:50
Topgun, I may love you. Problem solved, and with that my first ever exhaust mod. Sweet.
