Newbie with wheel bearing issues - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - News Desk > Newbie Checkin!
Newbie Checkin! New to the forums? Introduce yourself here!
Old 11-10-2009, 11:33 AM
danielfochtman danielfochtman is offline
danielfochtman is on a distinguished road
Default Newbie with wheel bearing issues
Hey y'all,
I'm Dan, i just got a 1996 Dodge Ram 1500 2wd (first mistake)
I had it for about a month and the front passenger wheel bearing started squeaking. Within 10 minutes the thing blew....The dust cap came off while driving and couldnt be found. I parked the truck and the outer bearing was ground to crap and other parts (washers, seal, etc) were all ground up as well. I replaced rotor/hub assembly. both bearings, the seal and the spindle nut, washer and lock with cotter pin. I also replaced the Dust cap.
Now, the dust cap, i had to hammer in. So it fit snug. After test driving it around the block (appx 4 miles) the new Dust cap blew out again. I have to buy a new one but i have no idea what would have caused it to pop out....that's 2 dust caps gone in the wind.
On top of this, the rotor/hub assembly feels warmer than the other side. I packed with a lot of grease so i'm not sure if i should take apart and pack more.
Any ideas?
Old 11-10-2009, 12:49 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Welcome to RamForumZ!!! Very interesting issue that you have...
Old 11-10-2009, 06:49 PM
Glad you joined us . If you could go to the top of the page to the User Cp and complete your profile that would be great . Helps us see what you have when your posting a question . Any pictures of your truck ? Any mods done or plans for future mods ? Any of your friends have Rams ? Tell them about us . We would love to have them . You will find this site is full of a lot of talented people . So if theres any question that you need answered , just shoot away . Talk to ya soon . Tom
Old 11-10-2009, 07:21 PM
LYC79's Avatar
LYC79 LYC79 is offline
Trim Level: SXT CRD 2.0 / 2.8
Rep:426
Hi Dan Welcome to the ForumZ Family!!!
I'm sure you'll find the help you need here.
Old 11-11-2009, 09:21 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Welcome to the Z!!! Glad to have ya
Old 11-11-2009, 09:37 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
The difference in perceived temperature could be part of the reason for the lost cap. As the assembly heats up, the tight fit you had initially will loosen due to thermal expansion.
It's possible you over-packed the bearing with grease and that is why it's running hot. I've seen this much more with turbo-machinery bearings though (12-36" in diameter - considerably bigger than a wheel bearing!).
Did you mic the rotor prior to assembly to be sure it was within spec? The bearing itself could be in a bind causing it to run hot if the bore is too small, out of round or not concentric to the spindle.
Interesting problem - especially given the large amount of 'new' parts you're dealing with. Keep us posted.
