Dodge Ram Decals
Old 11-10-2009, 02:55 PM
jjhwick119's Avatar
jjhwick119 jjhwick119 is offline
Vehicle: 2004 Dodge Ram Reg cab
Rep:97
jjhwick119 will become famous soon enough
Default 2/4 lowering question
alright, so ill start with that i got
2004 ram 1500 slt
reg cab
4.7
2" mcgaugheys drop shackled with overload leaf spring removed(i think thats what the leaf is called, lol)
now, first question...
if i were to do a 2/4 or 2/4.5 lowering kit, would i need to put the factory shackles back on? im not sure what all is involved with the whole truck lowering kit so i wasnt sure
next question...
i see a 2/4 and a 2/4.5 lowering kit....whats the difference? the 2" drop shackles didnt drop it it 2 inches, so i dont know what outcome to expect out of any of these. and since i took out the leaf spring im not sure if thats gonna make a dif in the type of kit i get
last question...
i can do any work on the inside of a car, ive dabbled in body work, and the only exterior work ive done on a car is doing my drop shackles. how hard is it installing the 2/4 kit? im not sure im able to do it...i can bring the truck up to work, we have jack stands, air compressor with air wrenches, and probably any tool id need, im just not sure how hard it is
thanks guys. appreciate any and all help!
04 Dodge Ram 1500 SLT 2WD. De-Badged
Regular Cab, Black. drop shackles in rear to level
Old 11-10-2009, 03:06 PM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
1. I would use what the kit comes with. if they say itll give u 2/4 then there is more to the kit.
2. I think that shackles take 1" before they drop so a 3" shackle would drop it 2 " I think it has somethin to do with the suspension load or somethin.
3. I have done lowering kits before and the more people u can get the better ur off. buy em dinner or somethin (pizza and beer) worked for me
Old 11-10-2009, 03:28 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
How much did the shackles actually lower? I am considering getting a set, also looked at the overload spring removal, but not real sure about that.
Old 11-10-2009, 03:36 PM
jjhwick119's Avatar
Rep:97
after putting in the shackles and removing the overload spring, the rear is still about 1/2 inch to an inch higher. not sure what stock height is. but they look good. it was a huge improvement and everybody noticed after i did it.
and from what i was told, its safe to remove the spring as long as you dont tow anything or have a really heavy load in the bed, which in my case i was fine with that
Old 11-10-2009, 03:45 PM
bigjeff64's Avatar
Rep:20
when i dropped my friends f150 it was a djm 3/4 kit with 3"shackles and 2" hangers in the rear and drop springs in the front
Old 11-11-2009, 03:03 PM
hawgfanman's Avatar
hawgfanman hawgfanman is offline
Vehicle: 2008 Ram 1500 QC Hemi
Trim Level: Lone Star
Rep:39
hawgfanman is on a distinguished road
The McGaugheys kit comes with shackles that have two sets of holes. One set gives a 4" rear drop and the other gives 4.5". If you reuse your stock shackles you'll end up with a 6" rear drop or if you used your drop shackles it would be about 8" of rear drop.
Old 11-11-2009, 03:04 PM
hawgfanman's Avatar
Rep:39
I didn't install mine but I've helped on a couple and as long as you have the tools and good jackstands, it isn't that hard.
Old 11-13-2009, 09:31 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
I bought EIBACH 4in drop leafs and cut the springs 3/4 of the coil. cheap drop but kept everything factory and no-one knows the differance
