Old 11-11-2009, 11:22 AM
RoughneckRam's Avatar
RoughneckRam RoughneckRam is offline
Vehicle: 2012 2500 Longhorn 4x4
Trim Level: Laramie Longhorn
Color: BLACK
Rep:38
RoughneckRam is on a distinguished road
Default Leaking Rear Window
I just washed the truck last night. When I went to get a towl out of the back I noticedthe rear window was leaking( right inline with the rain gutter on the roof ). Has anyone come across this problem? Any rcomendations on a fix without pulling the window and replacing the seall? Waranty ran out months ago.
Old 11-11-2009, 11:57 AM
Kens04's Avatar
Kens04 Kens04 is offline
Vehicle: 2004 Ram QC 4x4 HEMI
Trim Level: SLT OFF ROAD
Rep:48
Kens04 is on a distinguished road
Not sure but my 04 rear window leaks too. Seems to drain all the way to the storage under the seat. I had discovered it when I went to grab a roll of papertowels I keep under there and the whole roll was pretty much soaked. When i sound deadan the back wall (since the seats will be removed) Im going to pull the rubber trim out of the way enough to run a bead of silicone along the parimeter of the windows. Oh yeah, had a leak in the front too. Was dripping onto my knee from the top screw hole in the grab handle. Pulled the seal from the outside siliconed and good. Good luck.
Old 11-11-2009, 12:34 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Might try seeing if the seal has pulled away from the cab roof. Had that happen on my Pacifica.
Old 11-11-2009, 03:41 PM
ramit04's Avatar
ramit04 ramit04 is offline
Vehicle: 2004 Dodge ram 1500
Rep:74
ramit04 will become famous soon enough
what the crap mine does it too!!!!!!!!!!!!!!!!!!!
Old 11-11-2009, 04:13 PM
Color: BLACK
Rep:38
Ok, I talked to my brother (works at a dealership). He said he came across this twice so far, he had to remove the back window and replace the seal. I'm going to talk to a glass guy here in town and see what he says. It seems like too big of a job for me to do by myself.
Old 11-11-2009, 04:37 PM
chithead's Avatar
Rep:2078
Well that blows. Shouldn't cost too much for just a reseal.
Old 11-11-2009, 06:59 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Advance Auto has a product called Flowable silicone. Comes out of the tube a little thicker than water so it get into the crevices easily. Repaired a windshield leak with it about 5-6 years ago, still dry. I think it's only about $4.
Old 11-18-2009, 06:54 PM
Bullmastiff's Avatar
Bullmastiff Bullmastiff is offline
Vehicle: 2008 Dodge Ram 1500 Hemi
Color: Blue
Bullmastiff is on a distinguished road
Default Found the Problem !!
I have been having water leaking into the cab since I purchased my 2008 1500 brand new. It was so bad, I could not find the cause, I assumed it was the rear window. I decided to remove all the new , musty carpet and removed the rear seat and Line x the interior as I did on my Wrangler. I removed the rear panel in back and coated that as well. I extended the floor so it was a real nice rear storage area without the rear seating, that was all sealed with line x throughout. The window and motor were exposed but I made a custom panel to cover it in back and line x the rear panel as well. So, it rained, 2 inches of water underneath both front seats. Rear storage had 1 inch of water. Without the carpet to soak it up, it is really impressive to see. No water or dampness whatsoever under the rear window. But,,, the two rear air vents, unknown to most people, were pouring water... Water rolls down the rear of the cab and pours into these vents. It is so bad you would not believe it. There is nothing "defective" with the vents, its just that they are open to air and water just runs in. A pure design flaw that I don't even know if dodge is aware of. The only reason I found out is because I gutted the interior to line x it and it became so apparent. Otherwise I was assuming it was my rear window as well. As to how to fix it, I have not done anything yet, but gueass the only way is to seal the vents shut.
Old 11-19-2009, 08:51 AM
08quadram's Avatar
08quadram 08quadram is offline
Vehicle: 08 Ram Quad 1500
Color: silver
Rep:22
08quadram is on a distinguished road
I had my rear window replaced because the seals around the slider were bad and the shiny black plastic was turning white. The dealer told me they found an area that didn't have adhesive on the glass to the truck. He said that he had replace several that were not sealed to the truck cab. He likened it to an air bubble in a caulk gun at the factory robot installation. That makes sense to me, but it is a problem.
Mike
'08 1500 Ram, Quad 4x4 Bighorn, Silver, 20" wheels, 5.7 Hemi/MDS, 3.92 axles
"Meddle not in the affairs of dragons, for thou art crunchy and good with catsup" -Doc, IFSJA
Old 11-19-2009, 09:10 AM
Kens04's Avatar
Rep:48
Well, you have an 08 and I have an 04 so they have bubbles 4 years later in the sealer tube. Im not paying anyone to seal something I can seal, I sealed my front winsheild when it was leaking throught the A pillar onto my knee and now its bone dry. The back window will get the same GE silicone treatment just like the front, just got to take the rear seat out to do it properly and get it all up in the crack (l), hehe!! It does suck though, it ruined my air compresor I had in the storage comapartment cause it leaked all the way down. Take out the rear seat seal it up and sound deadan the back wall while your there, apparently deadaning the back walls in pick up trucks makes more differance than most would think, we will see.
