Old 11-12-2009, 01:37 PM
ThunderRoadRam's Avatar
ThunderRoadRam ThunderRoadRam is offline
Vehicle: 2005 Dodge Ram 1500 Thunderoad
Color: Gold
Rep:26
ThunderRoadRam is on a distinguished road
Default Best Differential oil
hey guys im getting ready to change my differential oil and was wondering what your opinions were on the best synthetic differential oil and also if anyone has used a K&N airfilter in there truck and if it is actually worth the money performance and gas mileage not the cold air intake system but just the filter itself that replaces your stock one
Enforcer
Mopar Mafia
Old 11-12-2009, 06:09 PM
I would recommend Amsoil . Don't waste your money on the drop in filter . Buy a CAI . K&N has a FIPK . Have one on my truck . Noticed a difference . Drop in filter was a waste of money .
Old 11-12-2009, 11:31 PM
AK2500's Avatar
AK2500 AK2500 is offline
Vehicle: 2006 Ram 2500 Mega Cab
Color: Blue
Rep:30
AK2500 is on a distinguished road
Amsoil x 2......75w-90 Severe Gear or 140w if you are doing alot of towing..
Old 11-12-2009, 11:43 PM
Amsoil is good stuff. Royal Purple is great too!
Old 11-13-2009, 12:30 AM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default Gear oil
Just what i needed to know. Changing mine. Thanks
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
Old 11-13-2009, 12:35 AM
SPEEDFREAK's Avatar
Color: SPEED WHITE
Rep:180
Default Gear oil
Sorry ill get the pictures stright next time. Working on my grand dads boat. Later
Old 11-13-2009, 01:12 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
Speed Freak, your truck rocks! And like what Tom said earlier, if you're going to upgrade your air filter just go straight to a cold air intake system. If you're going to do it, do it right from the start. If you wanted to do something half-arsed then you may as well have bought a Tundra instead of a Ram!
Old 11-13-2009, 05:14 PM
ScatPak07's Avatar
Rep:970
Yea CAI would be the best thing to do not the replacement filter. Yea amsoil for sure or Royal Purple
Old 11-16-2009, 10:14 AM
smartel's Avatar
smartel smartel is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Crew/Sport w/HEMI
Rep:47
smartel is on a distinguished road
Don't forget the limited slip additive! Some gear oils have it already (like Royal Purple) but most don't. If you have limited slip, which I'm sure you do because you have an R/T, you NEED the additive! If using a gear oil that doesn't have it, you'll need 4oz of LSD Additive.
09 Crew Cab Sport, HEMI, Line-X spray in liner, 4.10's with limited slip, Diablosport Predator, K&N Filter, Mufflex/Magnaflow 24" muffler--best 1/4 mile 14.200 @ 95.76 mph (with 4.10's and no tuner)---Modding is far from complete!
Old 11-19-2009, 01:43 PM
GOOSE's Avatar
GOOSE GOOSE is offline
Rep:43
GOOSE is on a distinguished road
Very true that some gear oils need the additive (if it's a lower quality). I would recommend AmsOil 75w-110 Severe gear lube and it's already made for limited slip. You will still get the same power and fuel economy (if not more) by using this. Hope this helps.
