Front axle leaking after u-joint change - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-13-2009, 06:46 PM
LittleMoe's Avatar
LittleMoe LittleMoe is offline
LittleMoe is on a distinguished road
Default Front axle leaking after u-joint change
I hope i am posting this in the right spot .....
I have a 94 1500, danna 44 front axle. I just replaced the axle u-joint and hub assembly(right side). After getting it all back together, i drove it a few miles, and now i noticed gear lube coming out of the axle tube. Am i gunna have to pull the axle back out, the pull the diff cover and replace a seal??? All i did was pull the axle out, replace the joint, then push the axle back in ... did i mess up the seal???
Thanks for any and all help !!!!
Old 11-13-2009, 08:56 PM
MRRMX MRRMX is offline
Vehicle: 2007 Ram Quad cab 4x4
Color: grey
Rep:12
MRRMX is on a distinguished road
I would bet the spring in the seal came out of the inner lip of the seal.
Old 11-13-2009, 10:20 PM
LittleMoe's Avatar
OK, so how do i solve that problem???? i have to take it all apart again ???
Old 11-13-2009, 10:29 PM
red041500 red041500 is offline
Vehicle: 2009 ram 1500 crew cab
Color: bright silver
Rep:22
red041500 is on a distinguished road
unfortunatly...... yes your going to have to replace the seal. when reinstalling the axle try not to let it drag on the seal all the way in. like stated you probably knocked off the spring or tore the lip of the seal.
Old 11-13-2009, 11:42 PM
LittleMoe's Avatar
OK, next question. Where do i find a procedure on how to replace the seal??? is it a pretty simple job??? i can't find a reference or pics of it in the Haynes manual .........
any suggestions????
Old 11-15-2009, 10:05 AM
LittleMoe's Avatar
any ideas??? I would like to try and fix this today ........
