Old 11-15-2009, 01:41 PM
jsirmg jsirmg is offline
jsirmg is on a distinguished road
Default Heater Problems
04 Dodge Ram 1500- When heater is turned on heat comes out of defroster and heater vents. Any ideas on problem. Thanks.
Old 11-15-2009, 02:37 PM
ungluedcargo's Avatar
ungluedcargo ungluedcargo is offline
Vehicle: 2008 Dodge Ram Megacab 1500
Color: Inferno red and khaki
Rep:24
ungluedcargo is on a distinguished road
There is a common problem with our trucks, the blend door breaks. It is a cheap part, its the labor at a shop that will kill you on it. They have to remove the dash to get to it. You can do it yourself, and there is a couple parts that are b etter than oem. If you google Dodge Ram broken blend door you will see alot of stuff about it and some repair instructions if you want to do it your self.
2008 Dodge Ram 1500 Megacab Laramie with a bunch of stuff. It all started innocently enough.
Old 11-15-2009, 03:36 PM
Yup, what he ^^^^ said. Common problem with these trucks.
Old 11-15-2009, 04:09 PM
Thanks for the information. I have had the dash apart before to replace the fresh air door that broke.
