Old 11-15-2009, 07:35 PM
dubsteve dubsteve is offline
Vehicle: 2009 Dodge Ram 1500
Color: Stone White
dubsteve is on a distinguished road
Default HID Help Needed. (Fitting Quad Headlamps)
Hi,
SO I have an 09 Laramie with the Quad headlights. I brought a H11 HID kit, and went to install it today only to come across the following problem
Because of the quad headlight setup, the high beem and full beam bulbs share the same wiring (3 wires in total enter the headlamp unit.) The connector on the outside does not match the connector on the HID kit.
When I look to remove the bulb, the connector there is correct, but how have other run the wiring into the unit? There is no way it seems to add the HID wiring?
The HID kit also came with the seperate direct batery connection, here is a link to the HID kit intall diagram:
http://www.xenonhidworlds.com/ztec-install.pdf
Any help would be great, anyone installed a HID on a quad headlamp system and worked around the original wiring without cutting it?
Steve
Old 11-15-2009, 08:21 PM
Not really sure myself . Hopefully somone who has already done this mod will stop by and give you some advice .
Old 11-15-2009, 09:24 PM
LadyRam's Avatar
LadyRam LadyRam is offline
Vehicle: 2009 Dodge Ram 5.7L Hemi Crew
Color: Stone White
Rep:56
LadyRam will become famous soon enough
I'll see if I can find other pics
'09 Dodge Ram CC Laramie 5.7L, Stone White; fully loaded
Mods: Chrome Gas Door, Chrome Bedrails, Chrome Bug Shield, Chrome Oval Steps, Access Cover, Rhino Liner, Tinting, Stainless Door Sill Guards, Flowmaster 50 H.D., Recon LED Lightbar, K&N Filter, Power Tailgate Lock, EZ Down
Old 11-15-2009, 09:30 PM
LadyRam's Avatar
Color: Stone White
Rep:56
found this one
Old 11-16-2009, 10:54 PM
Color: Stone White
So how did you re-connect the wiring harness? Looks like you have drilled holes in the back of each bulb holder cover, then have the wiring coming out for each of the Low and High beam, but then how have you connected to the stock wiring harness?
Thanks in advance!
Old 11-17-2009, 04:49 PM
NOLA RAM NOLA RAM is offline
NOLA RAM is on a distinguished road
I installed an HIDExrta kit yesterday. Make sure you have the capacitor. The HID ballast is going to connect to the factory wires that originally connected to the low beam lamp. Once you have the lamp removed you will probably need remove the factory clip from the white connecter so it will then connect to your ballast set up.
Old 11-17-2009, 09:21 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
dubsteve,
Please keep us posted with all information you find and progress on your install. I have the same kit from them waiting in the garage for me after re-hab for triple bypass. I haven't even opened the box yet.
GOOD LUCK with your project, I know it will be worth it.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 11-17-2009, 09:28 PM
lasstss lasstss is offline
lasstss is on a distinguished road
Originally Posted by Studbuster View Post
dubsteve,
Question. I tried to remove a headlight, I took 2 bolts out and something in the back was holding it in. I was afraid to pull it. What is in back holding the lamp in??
Old 11-18-2009, 12:33 AM
in the front of the wheel well there is a door, open the door inside there is a white tab push it up. That will release the assembly.
Old 11-18-2009, 08:39 PM
Fantastic, thanks for the info. Now I can wire up my Rams' beady eyes..
