2002 ram 1500 large evap leak - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-17-2009, 09:57 AM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Default 2002 ram 1500 large evap leak
please help guys last week had a small evap leak replaced gas cap all better light came back on this week large evap leak does anybody know whats going on
Old 11-17-2009, 10:06 AM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
Most of the time, a large EVAP leak can be seen easily...Since you already replaced your gas cap, it could possibly be a loose or cracked vacuum hose, EVAP canister leak...Check under the hood yourself, and inspect all the vacuum hoses, and make sure they are connected and not cracked or torn...
Old 11-17-2009, 10:10 AM
Vehicle: SRT-10
Rep:434
so it should be a vacuum hose under hood i will go check it do i have 2 disconnect the battery every time 2 get light 2 go off
Old 11-17-2009, 12:47 PM
frezingbelow frezingbelow is offline
Vehicle: 2001 Dodge Ram 1500
Color: Black/Silver
Rep:135
frezingbelow will become famous soon enoughfrezingbelow will become famous soon enough
Had the same problem in my 01, turned out to be my gas tank filler neck
Old 11-17-2009, 12:54 PM
Rep:47
Im taking it you mean the check engine light??? If so, then you can erase the codes with the code reader, but unless you find the issue I would leave it on because it is obvious there is an issue, and if you decide to take it to a shop they are going to want to read the code themselves...
Old 11-17-2009, 01:55 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Got the same with my 01, 5.9. Evap solonoid and leak detector pump should be on the passenger side fender, toward the front. Back track all vacuum hoses, under the truck, to the evap canisters. Several hoses on top of that. Anything that even looks suspect should be changed. I went the extra an put zip ties on all connections, just to make sure they are tight. Once you clear the code, it can take a while for it to come back on, so best not to reset until you have the problem fixed. Here's a couple of links that might help explain how the system works. Hope you have better luck that I'm having with mine. I think I am going to have to have it smoke tested.
http://www.obd-codes.com/forums/view...php?f=2&t=4124
http://****************/forums/viewtopic.php?t=72414
Old 11-17-2009, 01:56 PM
Color: Garnet red
Rep:202
Let's try that second link again.
http://****************/forums/viewtopic.php?t=72414Lin
Last edited by deanthecrabman; 11-17-2009 at 01:57 PM. Reason: link not appearing.
Old 11-17-2009, 01:58 PM
Color: Garnet red
Rep:202
One last time:
Old 11-17-2009, 01:59 PM
Color: Garnet red
Rep:202
Sorry, don't know why this is not working. Replace the asterisks with "****************"
Old 11-17-2009, 04:40 PM
Sorry... competing forum links get asteriked out by the software here.
I agree, it's either the evap cannister itself or the lines to and from it.
some autoparts stores will read and clear codes for you for little or no money but disconnecting the battery is probably the cheapest and quickest way to clear them.
One other option is to find your AutoShutOff/PCM fuse under the hood (you'll need a fuse location chart - see the Owner's Manual) and pull that fuse for about a minute.
