Old 11-17-2009, 02:02 PM
dustcosta dustcosta is offline
dustcosta is on a distinguished road
Default Baja Pre-Runner
I have a 2007 Dodge Ram 1500 4.7l 2wd and would like to lift it and sort of make it a baja pre-runner. Any one have any ideas or if they make something like this that I can install for a 2wd. I have looked over the internet and I could not find anything that fit what I wanted. Please help.
Dustin
Old 11-17-2009, 02:09 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Regular or Quad cab?
I love the pre-runner look too.
Old 11-17-2009, 02:10 PM
Its a Quad Cab
Old 11-17-2009, 03:59 PM
canuckboy's Avatar
canuckboy canuckboy is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: None
Rep:114
canuckboy will become famous soon enoughcanuckboy will become famous soon enough
I know Fabtech makes 2WD lift kits... im going with one for my 98' RAM 2WD.
Heres the link if its what you are looking for
Looks as though they only have up to 2006 listed for kits. Maybe if you contacted them at there toll free number in Cali. they could help you out.
http://www.fabtechmotorsports.com/ht...xdodge2wd.html
Old 11-17-2009, 04:22 PM
Some of the manufacturer's, like FabTech as mentioned by canuckboy, have spring spacer caps which will raise your truck in the front by about 2 - 3". They fit over the top of the front spring, which you reuse your stockers, and fit into the spring pocket at the upper arm.
I think Superlift and Rough Country also have them.
Old 11-17-2009, 04:25 PM
chithead's Avatar
Rep:2078
A 6" lift long travel suspension would be sweeeeeeettttttt!!!!!!!!!
Old 11-17-2009, 04:27 PM
I really dont want a leveling kit. I would like a lift/suspension for the truck. I would like it to be able to use it to actually run the desert.
YES IT WOULD!!!!!!
Old 11-17-2009, 04:28 PM
Then go with that FabTech kit then.
Old 11-17-2009, 04:30 PM
I might actually have to peice this kit together to make it what I want I dont know if they actually make a long travel baja/prerunner kit.
