Old 11-17-2009, 04:17 PM
flores1091's Avatar
flores1091 flores1091 is offline
Rep:17
flores1091 is on a distinguished road
Question Help any one????
i droped the back of my 95 dodge ram 1500 by switching the leafs to the bottom. but it sits on the bumbstops. this is a project car and dont mind cutting a few things here and there. people told me to cut the bumbstops shorter. or to c-notch the frame.
soo if i c-notch the frame. how much do i gota cut? and it wont cause the back to bend?? i dont carry nothing in the back or tow anything..
or could i take another leaf spring out of another dodge at a salvage yard and put it in. would that help raise or stiffin the rest of them?
the exaust comes close to hitting the rear shock in the back.. so if i can keep the hight or raise it just a little would be better..
(i have no bumber cause im getting a rollpan<if thats what there called)
Old 11-17-2009, 04:21 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Cutting the bumpstops is a good idea. C-notching requires additional bracing to compensate for cutting the frame.
Old 11-17-2009, 04:23 PM
Yeah, I'd start with the bump stops first. C-notching a frame is all about cutting, gusseting and welding which is best left to someone who's done it before.
Old 11-17-2009, 07:21 PM
flores1091's Avatar
Rep:17
ok soo here it is with out the bumb stops..
i took it for a careful drive around the block. and the bouncing stoped.. but there isnt much travel for the suspension.
even with a small pice of the bumbstop i knw it will hit at times.. an i dnt want that..
how much do i gota cutt for soo it wont? this truck isnt for off road or nothing..
Old 11-17-2009, 07:46 PM
chithead's Avatar
Rep:2078
I would think at least 1" of bumpstop would be ok. Enough to keep the rear end from hitting the frame.
Old 11-17-2009, 08:32 PM
flores1091's Avatar
Rep:17
and would that be enough clearance?
Old 11-17-2009, 09:10 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
I c-notched and didnt look back. Buy a c-notch kit so you have proper support and dont sweat it. I pull a 21' boat and nothing bends or has any issue at all.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 11-17-2009, 09:36 PM
flores1091's Avatar
Rep:17
would any local auto shops have any of those kits?
Old 11-18-2009, 12:02 AM
I push the skinny pedal
Rep:3308
You can order C-notch kits from Belltech or DJM, they both make a full kits that all but bolt on and give you the proper supports. You're looking at $150-250 depending on what you want. I'd recommend the Belltech myself as it gives you both a left and right plate that bolts into the frame.
http://www.stylintrucks.com/parts.as...tfamilyid=3334
Kurtis
Old 11-18-2009, 01:10 AM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
c notch kits are very dependable now as compared to the past. they have airbag kits that require u to cut front the front of the notch completely off and to bolt and weld the remaining frame back on. most c notch kits have bolt and welding spots for extra stength. plus the notch actually creates a box frame for the notch.
