Old 11-20-2009, 11:23 AM
ram4x4's Avatar
ram4x4 ram4x4 is offline
Vehicle: 2009 Dodge Ram 1500
ram4x4 is on a distinguished road
Default Hemi headers
Anybody know of any manufacturers out there that have high flow headers out there for the 09 5.7 Hemis? Want to swap out the manifolds, to restrictive, had a set on an 06 Ram that I had and want to do the same to my 09. I can't seem to find anything out there.
Thanks.
Old 11-20-2009, 12:46 PM
I push the skinny pedal
Rep:3283
You might have to wait a bit longer, I havn't seena nything for the '09s yet either except one set of shorty headers. Have to tried any local shops to see if they can fab up a set for you?
Kurtis
Old 11-20-2009, 01:07 PM
ram4x4's Avatar
I could, but wouldn't that void a warranty if it's not factory or aftermarket piece. Plus more expensive would it not?
Old 11-20-2009, 01:32 PM
Rep:3283
It won't void your warranty any more than the muffler you have welded in right now, a part has to CAUSE the problem, not just be present on the vehicle. If you melted your rear bumper due to high EGTs then yes...not warranty covered... but for most things, changing the headers/exhaust will not void warranties. If your dealership refuses to touch it cuz it's on then find another dealership since they shouldn't refuse to touch it.
For muffler shops, depending on where you go, but normally they're lower or a comparable price to aftermarket and you know they're made for your truck. Also make sure they have a mandrel bender not just a regular pipe bender, which can crease the pipe, and check their welding...make sure it's seamless, not sloppy tacks.
Kurtis
Old 11-20-2009, 04:15 PM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
Someone here definitely knows what he's talking about. Good recommendations. Yes, make sure they have a mandrel bender. Most shops do not because a good mandrel bender is very expensive and you need a technician with experience to do proper mandrel bends. As far as a welder, make sure they have a really good welder fab this up. Any college kid can claim to know how to weld, but remember that these exhausts go through thousands of heat cycles so that can destroy a cheap weld. Be sure you know what to look for. And go with a shop that has experience using stainless steel. Don't go for that aluminumized steel crap. If you do then you may as well have bought a Ford Ranger instead of a Ram. 300 series stainless steel all the way. And if all of that sounds too complicated, just wait a bit longer until Borla or Corsa come out with a rocking set of headers.
Old 11-30-2009, 09:55 AM
jkulysses jkulysses is offline
Vehicle: 2007 Ram Quad Cab
Trim Level: 2500 4x4 HEMI
Rep:68
jkulysses will become famous soon enough
Actually my 06 Ranger came with all stainless exhaust system haha.
Old 11-30-2009, 11:32 PM
Incognito's Avatar
Rep:72
A lot of vehicles from the factory come with stainless steel exhausts, but they're all 400-Series, and they're not heat treated. The only vehicle I know of that comes with 300-Series stainless that's heat treated was the C5 Z06, and the current C6 ZR-1. There is a big difference between 400-series and 300-series, as well as having the "T" designation of heat treated.
Old 12-01-2009, 08:51 PM
Might want to check out JBA headers . See if they have anything available yet .
