Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2009 Dodge Ram Forum
Old 11-19-2009, 08:57 AM
brinks13081 brinks13081 is offline
Vehicle: 2009 Ram 1500 Crew
Color: Brillian Black Pearl
brinks13081 is on a distinguished road
Default Octane
I was just reading my owners manual and noticed that it recommends 89 octane for my 09 5.7L Hemi. Is that what everyone is using?
Old 11-19-2009, 09:05 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Check this thread out, it will answer all of your questions
http://www.ramforumz.com/showthread.php?t=42505
Old 11-19-2009, 09:09 AM
Kens04's Avatar
Kens04 Kens04 is offline
Vehicle: 2004 Ram QC 4x4 HEMI
Trim Level: SLT OFF ROAD
Rep:48
Kens04 is on a distinguished road
Thats what I use. 89. Used 87 once, not sure there was any difference but if it prolongs the life of my truck then ill spend another 5 bucks a tank to make sure she drinks the best.
Old 11-19-2009, 09:43 AM
Yeah, pretty much they are unless they've installed a Predator 91 octane tune.
My 5.2L doesn't like 87 at all so I run 89.
Old 11-19-2009, 01:29 PM
Rep:3322
^^ agreed, only run 91 if you have to due to a tune. Or are in desperate need of cleaning your engine.
Old 11-19-2009, 08:08 PM
iRockCrawler's Avatar
iRockCrawler iRockCrawler is offline
Vehicle: 2009 Dodge Ram 1500
Color: Mineral Gray Metallic
Rep:44
iRockCrawler is on a distinguished road
Hmm. I misread the manual..
Old 11-20-2009, 02:23 AM
Smitty's Avatar
Smitty Smitty is offline
Vehicle: 2009 Dodge Ram 1500 4 x 4
Smitty is on a distinguished road
The Octaine rating of a fuel has nothing to do with cleaning an engine, nor is it going to make your engine last longer. There is absolutely no benefit of running a higher octaine than an engine is designed for unless it has been modified in some way. Just because it costs more doesn't mean it is better.
Old 11-20-2009, 12:08 PM
Bobcat06's Avatar
Bobcat06 Bobcat06 is offline
Vehicle: 2002 Ram 1500 Quad Cab
Rep:91
Bobcat06 will become famous soon enough
It is only more expensive because it costs more to make, not because it is better for every engine. The higher the octane means it is less likely to pre-detonate. It won't clean your engine, give you better mpg, or more power if your engine isn't set up to for it. Now if you are running a programmer, that is a different story, but it's best to run whatever the manual says is best for your engine.
Old 11-20-2009, 01:14 PM
Airdog's Avatar
Airdog Airdog is offline
Trim Level: Sport 4x4
Color: Detonator Yellow
Rep:37
Airdog is on a distinguished road
Smitty is on the right track...
93/91 octane fuel doesn't do anything to "clean" your engine. Detergents are added to fuels to clean them. A fuel with a higher octane rating is actually "harder to burn or ignite" under compression. You may get a little more performance from a higher octane fuel if the timing is retarded allowing for more compression before the fuel is ignited by the spark plug. Using a low octane fuel in a high compression/high horsepower engine will lead to pre-detonation or "spark knock" because lower octane fuel ignites much easier.
I'm not sure if the computer in the Ram will retard the timing for higher/lower octane fuels automatically. If it does, the difference will probably be negligable unless your running at the track and using timing devices. Probably why we see the programmers like the Predator used with success.
The compression ratio of your Hemi engine determines the octane rating of the gas you should use your truck. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. My old Durango R/T required 93 octane fuel (printed on the gas cap). The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight. The disadvantage is that the higher octane gasoline for your engine usually costs more.
Octane is a product of the refining process. When you take crude oil and refine it, you end up getting hydrocarbon chains of different lengths. These different chain lengths can then be separated from each other and blended to form different fuels.
Octane handles compression very well -- you can compress it a lot and nothing happens. Eighty-seven-octane gasoline is gasoline that contains 87% octane and 13% heptane (or some other combination of fuels that has the same performance of the 87/13 combination of octane/heptane). It spontaneously ignites at a given compression level, and should only be used in engines that do not exceed that compression ratio. Ninety-three-octane is 93% octane and 7% heptane (or other hydrocarbon) making it suitable for high horsepower engines because it won't ignite as easily under compression.
Dodge has the recommended fuel rating for a reason. Running 87 octane fuel probably won't cause detonation or spark knock (I've done it a few times with no problems). Just remember the computer is optimized for 89 octane fuel because of the compression ratio in the Hemi engine.
Just my 2 cents...
~Airdog .
